swoody126 wrote:by regluarly perusing CL i found a Lincoln 180(220v) just yesterday NIB
and @ the spry young age of 71 brought it home for $400
by time to close the barn doors yesterday evening it was assembled and passing nice welds on 1/4" structural steel scraps using .035 flux core wire(outdoors in a breeze) and set in the middlish portions on the 2 dials(amperage & wire speed)
never could find a 120v unit worth a tinker's dam
buy once cry once(i learned the hard/$$$ way and i now have a 120v Miller for sale REAL CHEAP)
sw
Philip wrote: Another reason I am saying 140 amp. Most of them run .035 wire. That I the easiest wire to find. If you get one using .020 or .025. A lot of places might sell the welder. But they do not sell the wire for it.
RJ Howell wrote:How much of a deal killer is this? Thoughts?
NevadaBlue wrote:Let someone else weld the aluminum.
So, for thin steel, an ordinary acetylene torch works fine. It is very much like using a TIG actually. I learned to weld auto body type metal with a torch and never looked back. I did buy the TIG for gun work, but it wasn’t really necessary. If you can torch weld, you can tig weld.
‘Bring it over, and I’ll weld up what you need.
Squigie wrote:...
If you really want an interesting discussion, ask an old aircraft builder about O/H welding (Oxygen/Hydrogen). People today think it's garbage, even though they've never seen it, let alone tried it (including myself). The old guys say ignorance is bliss...
What's right? What's wrong? What's my point?
They all work. They all have their place.
Some are easier to work with. Some are easier to learn. Some require less (or zero) touch-up. Some require less prep. Some result in a better end product.
You can't have 'em all. Pick what you want and find the weld process that ticks your chosen boxes.
KTM_Guy wrote:Yup, add a high frequency unit and you can weld aluminum. Won’t be as good as a dedicated TIG but it works. One of the reasons those old stick AC/DC welders are holding some value. Spend some time on Google or YouTube tons of info out there.
Todd
