Hello from Poland
Re: Hello from Poland
Postby cluttonfred » Tue Apr 07, 2020 1:21 pm
Fantastic project, the gloss red paint really makes it pop and goes beautifully with your 2CV. Thanks for sharing!
Matthew Long, Editor
cluttonfred.info
A site for builders, owners and fans of Eric Clutton's FRED and other safe, simple, affordable homebuilt aircraft
« Voici ce que j'ai fait...vous pouvez en faire autant! » "This is what I have done...you can do the same!"
--Henri Mignet (1893-1965)
cluttonfred
Postby Krzysztofpat » Sun Jun 07, 2020 3:17 pm
I don't know how to finish folding walls with a roof, maybe someone has an idea. In Poland, there are no angles to bend
Krzysztofpat
Krzysztofpat
Postby tony.latham » Sun Jun 07, 2020 4:08 pm
Krzy:
Something was lost in the translation. Try it with different words.
Postby Krzysztofpat » Mon Jun 08, 2020 9:06 am
I don't know how to finish folding the walls with a roof. Someone has an idea. greetings
Krzysztofpat
Krzysztofpat
Postby Krzysztofpat » Mon Jun 08, 2020 9:18 am
What finish to use, marked on the picture.
Krzysztofpat
Krzysztofpat
Postby OP827 » Tue Jun 09, 2020 8:51 pm
I think it is called insert roof edge molding . It is usually made of softer aluminium that can bend along the roof curve. Try searching it in your area or from online suppliers.
Good luck!
Oleg
OP827
Images: 414
Postby Krzysztofpat » Wed Jun 10, 2020 9:36 am
Thank you for your answer. I found something like this in a trailer store, will it bend in an arc?
Dok1.docx
(74.77 KiB) Downloaded 424 times
Krzysztofpat
Krzysztofpat
Postby OP827 » Wed Jun 10, 2020 5:56 pm
Krzysztofpat wrote:Thank you for your answer. I found something like this in a trailer store, will it bend in an arc?
Unfortunately I do not have a "fit-all" answer to your question. You will have to ask the store staff, generally it depends how soft the material is and how high is the edge that is resisting in the direction of the arch bend. Many aluminium alloys can also be annealed or softened by heating them, but you have to know what you are doing from the alloy composition properties perspective.
OP827
Images: 414
Postby Krzysztofpat » Sun Jun 21, 2020 11:47 am
Thank you for your help, I bought a slat and according to the angle bending tool from the forum I succeeded. Regards
Krzysztofpat
Krzysztofpat
Postby Krzysztofpat » Sun Jun 21, 2020 11:48 am
Krzysztofpat
Krzysztofpat
Postby OP827 » Sun Jun 21, 2020 4:43 pm
:thumbsup: :applause:
OP827
Images: 414
Postby Krzysztofpat » Fri Jul 17, 2020 4:45 pm
trailer ready for vacation
Krzysztofpat
Krzysztofpat
Postby pchast » Fri Jul 17, 2020 9:11 pm
The graphic looks nice too. :applause:
pchast
Images: 97
