juangp wrote:Your build sounds similar to one I want to get started on. I've been looking at different manufacturers and Anvil seems like a good one. Would you mind sharing why you picked Anvil? I'm in South Florida, so it looks like all of my options are coming out of GA. Also, do you think it's worth having the manufacturer install certain options like windows? It seems to me that what the manufacturer charges to install a window is just about the same as the cost of ordering a window online, so I would save myself the labor.
Richard, we will keep in touch..If I get out there as I want to and I do not get derailed by any other family crisis, I will see if we can meet up on the road. That would be fun!ris wrote:We are also heading west this year. Start at Big Bend 22 March, across southwest hitting parks out to Joshua Tree in 12 Apr then Pinnacles NP up through the NPs of California, and Oregon to Olympic NP 21 Jun in northern Washington. Not sure where we will go from there. Do not plan to be back in Florida until mid November. Maybe we will see you out there if not before we leave. We will enjoy watching your build. This year we are carrying the camping equipment so we can leave the trailer in a few places and get up into the back country in just the truck.
Richard
Grummy wrote:Sounds like you are about to have good times.... trailer build and USING it !
A couple of things came to my mind......
Add a column to that order spreadsheet you displayed for WEIGHT. Weigh everything as you build so you have a good record of WHAT is involved in your final scale total. For raw materials you can cut a 12" square, weigh it and later do the math via square feet involved.
I did not read whether the trailer will be coming with the interior walls in place, but I did see you will be insulating yourself. In my opinion, one really does have to fully GUT the trailer for a visual inspection, floor and all. Then do a full water leak test from all angles with moderate pressures. After buying mine, I was a little surprised (well, not all that much) as to the build methods. For example,where they put diamond plate on for protection, they end the trailer aluminum which means they fully rely on caulk to keep the water out of the walls. I also had water leak issues when spraying water in the back of the "screwless" seams.
Lastly, regarding Gross weight, while your adding the heavier axle, I've often wondered how the trailer builders decide where one can draw the line. In other words, could they say the quality of the frame and box could handle 7500 lbs ? 10,000 lbs ? I guess what I am saying is just because one puts a higher rating axle under wouldn't mean the rest of the trailer is good for it (not saying yours is not).
I'm not sure how I'd feel about making my 6x12 aluminum framed trailer a 5000lb trailer. I wonder what the company would be able to accurately say if I were to call and ask ? They probably couldn't commit to anything.
Looking forward to your build.
hankaye wrote: The main thing is the STICKER weight rating that is indicated by the Manufacturer......
hank
Grummy wrote:hankaye wrote: The main thing is the STICKER weight rating that is indicated by the Manufacturer......
hank
Indeed. I'm real curious what the mfg will put on this trailer tag given they have built it with the heavier axle.
One thing I know for sure is it is pretty hard to keep a 6 x 12, even an aluminum framed trailer under the 2990 as a "conversion" with Water, shower etc.,, especially if you intend to also haul a bike or ATV. I think I want to call Ameritech (manufacturer of my trailer) and ask what they tag a trailer like mine at with the one axle size up.
While I've seen some of these really light 6x12's, they obviously have less frame in them. Luckily I too have a triple tongue and 16" centers. Seems the OP has rode this rodeo before and also knew what he needed.
hankaye wrote:
Mine is a 6X14 Had the upgrade to a 5,000# axel with breaks and 7 pin plug. Sticker says 3500# .
