Wish me luck
but I'm leaning towards just using 1/2 inch birch plywood.
mattiker wrote:I'll look into seeing if I can find fir plywood, that sounds like it might work and a quick online look shows that it's much cheaper. That's a good note on the door as well, I might make the window fit into the door and move the door to fit about in the middle. Great points, thank you Tony!
I think I might also put a slight slope in the flat section of roof to help with drainage
tony.latham wrote:Any lumber yard will have AC plywood. When I say yard, I’m not talking box store.
T
what about fendersmove the door to fit about in the middle
tony.latham wrote:You want the bottom of the door frame half-way into the mattress. Otherwise, you'll be sitting on it, not the mattress when entering and exiting.
