Steam an issue when propane stove is mounted under hatch?
Postby bartek » Mon May 10, 2021 10:59 am
I'm finalizing my galley design, and looks like most folks opt to fix their propane stove on some sort of slide out.
I like the convenience, but was wandering if it creates any issues down the road, since I imagine the steam created when cooking would be directly hitting the hatch (which in my case is plywood with spar urethane finish).
Would love to hear from people with this setup and learn from the experience. Thanks!
Image 6x10 family teardrop, build thread: http://www.tnttt.com/viewtopic.php?f=50&t=73426
bartek
Images: 84
Re: Steam an issue when propane stove is mounted under hatch
Postby Sparksalot » Mon May 10, 2021 11:48 am
Mine is under the hatch. It’s been so for 13 years.
164545
Sparksalot
Images: 687
Postby tony.latham » Mon May 10, 2021 12:17 pm
Never any issues. Lots of ventilation back there. :thinking:
Postby TimC » Mon May 10, 2021 2:01 pm
Unless you're boiling off 1-1/2 gallons of wort you shouldn't have any problems. :beer:
Tim
Niagara, WI
TimC
Images: 751
Postby bartek » Mon May 10, 2021 7:17 pm
Thanks everyone, glad to hear I'm overthinking this :) Slideout stove it is!
bartek
Images: 84
Postby Tom&Shelly » Mon May 10, 2021 9:39 pm
TimC wrote:Unless you're boiling off 1-1/2 gallons of wort you shouldn't have any problems. :beer:
Exactly what we had in mind by keeping our stove separate from the galley
165075
Umm, but please don't tell the revenuers about that ... :shock:
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Postby dbhosttexas » Thu Jun 24, 2021 10:05 am
Yep, you are massively overthinking this. Cooktops have been under / in wooden compartments for decades.
Under the hatch on a teardrop is VERY well ventilated.
And like you said, you are using spar varnish on the wood, which is what they use on boats.
Do you think your stove / steam is going ot make and keep the environment more constantly humid than what a boat is exposed to constantly?
I'd go for the slide out just to be sure you have counter space to work with that the stove isn't taking up...
Good luck, and share pics of the build!
dbhosttexas
Images: 29
