Flex Seal. Really?
Flex Seal. Really?
Postby RJ Howell » Wed May 26, 2021 12:41 pm
I so avoid these types of marketing things, yet I've heard from a few good sources this stuff really works! Hmm...
Now I go into what is it and is it worth buying that brand? It's liquid rubber! I have some I use on electrical connection that are submersed. Is this worth the hype?
Interested in what others think about this brand or similar.
RJ Howell
Images: 36
Re: Flex Seal. Really?
Postby S. Heisley » Wed May 26, 2021 3:28 pm
Don't buy it. The original praise for the product is changing to damnation quickly. I'm hearing from a women's RV site that not only does the seal not last but that you'll have to pay Hell with cuss words and hard labor to get it off to seal your RV correctly later.
They make both a liquid and a tape.
If you're using it on something that will be replaced later, okay. I was given a roll of their tape for Christmas and I used some of it this spring for an emergency fix to a yard dripper hose. It helped long enough to replace and fix what was broken, although it still leaked a bit. But, what a mess! I don't think I'll ever get the goo off the scissors I used to cut the stuff!
Postby GerryS » Wed May 26, 2021 7:38 pm
I would imagine it’s good for some uses, but not all. What are you trying to accomplish? Butyl tape, eternabond, and dicor are my go to products to stop leaks….
But what are you trying to do?
GerryS
Postby RJ Howell » Thu May 27, 2021 6:53 am
Coating steel frame of the pickup and the plywood base of the camper (underside). I see other liquid rubber products out there...
RJ Howell
Images: 36
Postby saywhatthat » Fri May 28, 2021 11:57 am
total crap no UV protection and will crack after a bit. A whole day to get it off of a trailer that I was stupid enough to put it on with a wire brush. Rust-Oleum makes a product the same thing that will get hard and could be painted over .There's many bad reviews on this stuff has anyone that uses it gets what they deserve. again I was totally stupid enough to try it once
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby tony.latham » Fri May 28, 2021 1:55 pm
I'm always suspicious of something that is sold as if it's the latest greatest snakeoil.
:frightened:
T
Postby TimC » Fri May 28, 2021 8:42 pm
But wait... didn't they build a boat with a screen door as the hull and it floated. Next time I build a boat with window screen I'll definitly use that stuff. :lol:
Seriously though, my neighbor, who tends to be quite gullible, bought a case of the stuff cause it was such a good deal. He tried to fix a leaking rain gutter on his house. Total fail. Been trying to give away cans since. He's asked me if I want a can. No thank you.
Tim
Niagara, WI
TimC
Images: 751
Postby PCO6 » Sat May 29, 2021 6:19 am
I don't have any experience with their rubberized paint but I've used "Flex Tape" (same company) many times. It works well as a gasket between a metal bracket and a painted surface for example. Based on that I'd be willing to give it a try.
PCO6
Postby saltydawg » Sat May 29, 2021 10:51 am
The original flex tape was just ice guard roofing underlayment. It has no uv protection.
I saw something about the guy who came up with it, he was buying 200 buck rolls of ice guard and selling the strips for around 1500 bucks. I wish I came up with the idea
Scott
Lost in Maryland
saltydawg
Postby Dahlia47 » Tue Jun 01, 2021 10:21 pm
I used the liquid and the tape for my roof. It worked. I used the tape where the 2 boards met. put some bricks on it for pressure. the next day I painted over it with the liquid. So far so good. Only 2 spots recently with a small leak. Downsides...cant paint over it, a bi111 to remove, pricey, doesn't last too long. Will it keep my ttt from sinking? Nope. When I saw the commercial for the floating whatever it was, I laughed. Cheesy! lol I think it's more for short-term "fixes".
Dahlia47
Postby RJ Howell » Wed Jun 02, 2021 5:35 am
My intent has always been to under coat my camper with it. I ended up going with another spray rubberized product.
RJ Howell
Images: 36
Users browsing this forum: Google [Bot] and 10 guests
