Great info! This helps immensely!Tom&Shelly wrote:I think your idea will work. That iron grate floor should help ventilation.
FWIW, here are some pictures of how we did our Climatright. I was nervous about that front cargo door taking rocks, but it's done okay so far. We open that door when running the AC and seems to be enough. I designed it so we could open the side cargo door as well, but found it isn't necessary.![]()
The AC has a drain pipe at the bottom. I drilled a hole in the floor and attached a hose, but we still get water in the utility compartment. I don't know if the hose pulled out or the AC drips other places besides out the pipe. When the weather warms up, before we head out this Spring, I'll redesign it with a drip pan under the unit. We traveled in the muggy midwest and northeast, and got a lot of water out of the air. Not something to neglect! (Should be high quality distilled water, if we recovered it and stored it somehow. Too bad we seldom use our iron in the wilderness.)
Oh, for the AC, we found it works better to disconnect that return hose and take the air right from the outside. Otherwise, the unit freezes up after an hour or so.
mnjeepguy wrote:I don't have a trailer yet, but it is being built. When thinking of heat and A/c, I consider the conditions I have tent camped in.
Regarding heat:
One miserably cold night I had a 50 degree bag and a tent. Forecast was way off and it dropped into the 20s. I was uncomfortable, but better planning and I would have been fine. Been into the 30s a few times with better bags and such, in a tent. With the trailer inherently being more insulated, and better bedding...I don't expect my travels to need heat. If they do, I will get a diesel heater since it will be rare use and likely away from shore power.
Regarding A/C:
This may get interesting. I've tent camped in 100+ degree weather. It's not great. The insulation of the trailer might make this worse. I will have two windows and a Maxx fan (bidirectional). Fingers crossed that is enough.
mtbikernate wrote:
I saw in another thread that you've got a Hiker on order. I've had one for almost 5yrs.
When I ordered mine, I expected that I would find a need for A/C. That has not been the case. I've had MORE of a need for heat in shoulder seasons where it gets up into the 50s-70s during the day, but drops down to or even below freezing at night.
So far, when on shore power, I've just used an electric blanket to supplement and that helps, though only so much.
When off-grid, condensation is an issue since I'm buttoning things up really tight, even above freezing but still with cooler nighttime temps. If I ventilate heavily to keep condensation down, I get a very notable COLD breeze inside which makes it feel a lot colder inside than out.
I'd love to get a propex, and one has been on my list for awhile. But I've got so many different things to address that I think I'm going to start with a diesel heater and an external in-a-box type install. I got the A/C prep from Hiker, and that makes it pretty easy to plumb in the heater. That way, I can do a propex install later and not need to undo a bunch of stuff.
I think a couple factors are important with my lack of need for A/C. First off, I got my trailer built in white, which reflects the sun's energy during the daytime. I've parked my trailer in direct sun on some pretty danged hot trips and have been surprised at how cool it stays inside with no fan, and only windows open. I also try to park in some shade when I can. I also did get the MaxxFan upgrade from Hiker. That fan moves a lot of air, and on warm/humid nights it definitely helps keep things manageable inside.
I find tents in the heat to be a LOT more uncomfortable. The fabric radiates heat in a bad way. I was absolutely blown away when checking out popup trailers on a warm (but not really what I'd call hot), sunny day, at how horribly uncomfortable they were compared to the solid trailers I visited in the same weather. None had A/C actively running, but the popup trailers truly needed it.
mnjeepguy wrote:My first question. Would you order the hiker again? I looked and complaints seem pretty low, so I am hopeful.
The heat/vs cool thing may be interesting. I ordered mine in charcoal, and later wondered if that will be an issue in summer. The roof is white...so that should help in hotter times. Maybe I can use it to my advantage on cooler days with sun. I did get the Maxx fan as well. Right with you on the little diesel heater in a box. My plan is the same if I feel I need one. Box makes it useful/easy to remove. I have to see if I use it in cold weather enough to dump a grand into a propex. I'll have a German heater with me by default. It's the Shepherd model
featherliteCT1 wrote:My Chinese diesel heater averages about 2 amps per hour, over an eight hour period, when it is about 30 degrees outside. So, about 16 total amps over an eight hour period.
