Ceiling vent in the rain
Re: Ceiling vent in the rain
Postby friz » Sat Mar 19, 2022 6:14 pm
mtbikernate wrote:
tony.latham wrote:
They are overly sensitive to battery voltage.
Interesting. Makes me happy to have a Fantastic. ;)
Thanks,
I'm still happy to have the reversible fan motor and the better cover to keep rain out. 10 speed settings is more than I need, but aren't really a problem, either. wouldn't cost the mfr much to either give the thing some voltage protection, or at least give it a wider possible range of working voltages so it's not so sensitive. but apparently they're plenty happy giving out control boards via warranty and selling more besides.
it's a tiny thing, and it's a fixable/preventable problem. so it just winds up being an irritation more than anything.
I removed the 3 sp control on my fantastic fan and replaced it PWM motor control from ebay. Its the one with the remote potentiometer so I was able to use the original hole and knob for speed control.
Sent from my SM-G965U using Tapatalk
The "Sin Bin"
150133
friz
Postby Gulfcoast » Sat Mar 19, 2022 10:32 pm
I bought a Fantastic fan with no control board, and added a clear plastic cover over it.
I can leave my fan wide open in any rain and no water comes in.
6x12 cargo trailer - Mini Split A/C - Starlink - TMobile home internet
Gulfcoast
Postby lfhoward » Sat Mar 19, 2022 11:20 pm
friz wrote:I removed the 3 sp control on my fantastic fan and replaced it PWM motor control from ebay. Its the one with the remote potentiometer so I was able to use the original hole and knob for speed control.
Friz, do you have a picture or link to the type of PWM controller you got? I looked into these before but never found one that would work with the original speed knob. Is it this one? https://www.tnttt.com/viewtopic.php?f=50&t=67288&view=unread#p1288951
lfhoward
Postby friz » Sat Mar 19, 2022 11:57 pm
That one is too small for the fantastic fan. The one I used looked like this one. I do think that it required a little bit of modification to the post or the knob to allow it to work. These kind of projects always require some "hot rodding"
https://www.ebay.com/itm/DC-12V-24V-15V ... 632-2357-0
The "Sin Bin"
150133
friz
Postby lfhoward » Sun Mar 20, 2022 4:07 pm
Thank you, Friz. Apologies to the original poster for the thread hijack.
lfhoward
Postby philpom » Mon Mar 21, 2022 5:25 pm
lfhoward wrote:Thank you, Friz. Apologies to the original poster for the thread hijack.
Not necessary, this is all great "van relevant" information.
philpom
Images: 103
Postby philpom » Mon Mar 21, 2022 5:31 pm
Graniterich wrote:So what I did was buy the single direction four speed from maxxair, cheapest one. Removed the control board, and put in a dpdt toggle switch and a pwm controller from Amazon. Fit perfectly, under twenty bucks. I now have the best of both worlds, totally variable speed with reverse. It is also very effeceint due to the pwm pcba
Sent from my KFTRWI using Tapatalk
Can you tell me what maxxair model you have? Also, do you have links for the dpdt switch and pwm controller you purchased?
Another question, I found some affordable maxxair 14" fans but from the pictures I can't tell if they come with the inner molding/trim piece. Some of them look like they literally just screw down on top and you are left to finish and trim it yourself.
Thanks!
philpom
Images: 103
Postby Graniterich » Mon Mar 21, 2022 6:00 pm
Thanks!
https://www.amazon.com/gp/product/B01M1HSYO7/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I swapped out the square switch with toggle, easy to drill round hole.
Here is the fan Maxxair 00A04401K Smoke Roof Top MaxxFan with Mounting Tabs
https://www.amazon.com/gp/product/B010D ... UTF8&psc=1
Graniterich
Postby Cosmo » Fri Mar 25, 2022 9:19 pm
My MaxFan is 7 yrs old. I have the hand crank model, not the remote control model.
I have had it out in lots and lots of bad weather in all seasons.
Often I leave the vent open - no fan running. In that case, no water comes in unless the wind is blowing hard in the direction of the intake and pushing the rain directly at the air intake/exhaust, I will start feeling a few drops.
In that case I close the vent and open a window or other ventilation ports.
If the wind is blowing rain hard at any of the other 3 sides I am getting no rain.
Its been a good vent for me.
=Cosmo
FUN WITH TEARDROP TRAILER VIDEOS
https://www.youtube.com/CosmoWeems/videos
I am an Amazon Associate if you buy from my links I may profit at no cost to you!
Cosmo
Users browsing this forum: Bing [Bot] and 6 guests
