lfhoward wrote:In redoing the 120VAC wiring I reversed the inputs on the Automatic Transfer Switch. Since we most often boondock, I made the inverter the primary AC source. Shore power will be secondary.
bdosborn wrote:P.S. I'd consider putting a MRBF on your battery positive terminal to supplement the DC breaker. Fuse are much faster acting than breakers and limit the fault current more than breakers do. Breakers are also notorious for failing under high fault current conditions.
featherliteCT1 wrote:I am now picturing you painting your trailer Victron blue, wearing a Victron T shirt and a Victron hat.
