FoxDen Electrical Schematic Review
Anything electric, AC or DC
Postby foxontherun » Sat Jan 13, 2024 10:51 pm
Good evening,
I have created a simple schematic of what I am attempting to do. Would appreciate feedback/suggestions on what to do or not do to improve it and to make sure that I do this in a safe manner. Thanks is advance for all suggestions and input.
Harry :)
172881
foxontherun
Images: 91
Re: FoxDen Electrical Schematic Review
Postby tony.latham » Sat Jan 13, 2024 11:04 pm
I'm a 12-volt only camper, so the thing that caught my eye was the 80-amp breaker for your 12-volt system.
Mine is wired for 15 amps. What are you going to power with it? Wouldn't that need 3 or 4 gauge wire? Which is about as big around as my little finger?
I think the feed to my shop is 100 amps... :frightened:
:thinking:
Postby Pmullen503 » Sun Jan 14, 2024 8:42 am
Why a shunt between your battery and negative bus?
Pmullen503
Images: 67
Postby tony.latham » Sun Jan 14, 2024 10:14 am
Pmullen503 wrote:Why a shunt between your battery and negative bus?
I've got one in the same spot that my AiLi battery monitor uses. (Which is a great $40 gizmo.)
Postby foxontherun » Sun Jan 14, 2024 11:39 am
Good morning,
Tony, my fuse block is a 100 amp Blue Sea 5026. I will probably never get close to using all of it; my current set up (Cargo Trailer Build) totals about 40 amps (fans, lights, cpap with humidifier, tv, stereo, water pump, charging station). I do tend to overbuild, ha! I doubt I will ever come close to the full capacity on that block. The wire chart I used said #4 AWG for 100 amp.
Pmullen, I use an AiLi battery monitor as well and that is the location my instructions had.
Thanks,
Harry
viewtopic.php?f=42&t=72881
foxontherun
Images: 91
Postby tony.latham » Sun Jan 14, 2024 12:36 pm
The challenge will be attaching that size wire to the fusebox. 4 AWG is like jumper cable wire.
I use the same box.
My feeder line from the battery to the fusebox is #12 AWG, just like an AC circuit in my home except it uses multi-stranded copper. A 15 amp breaker protects it. Ceiling fan, lights, USB ports, CPAP, Propex heater, and sometimes charge my laptop. Nary a blown fuse or popped breaker.
Postby featherliteCT1 » Sun Jan 14, 2024 6:06 pm
If it were me, I would post your diagram and question on https://diysolarforum.com .
The people on that forum are incredibly knowledgeable, passionate about electrical systems and love to help people with builds.
featherliteCT1
Postby foxontherun » Sun Jan 14, 2024 8:53 pm
Thanks featherlite, I will check that out. :thumbsup:
Harry
foxontherun
Images: 91
Return to Electrical Secrets
