Get fiberglass cloth, not chopped?
Tom&Shelly wrote:The information from 2016 should still be correct. I think I remember that you don't want to use chopped fiberglass with epoxy, but maybe someone else can chime in to confirm or refute?
I've also heard, but can't confirm that fiberglass is actually just about the same price as PMF. I've never used PMF so don't know.
tony.latham wrote:Get fiberglass cloth, not chopped?
Most matt is glued together with a substance designed for polyester resin to dissolve. It's not meant to be used with epoxies and I quit using polyester resin a couple of decades ago. Don't use the stuff for a woody.
I have used a few gallons of Raka epoxy. It's good stuff, and their cloth is too. 6 oz cloth is fine for sealing plywood.
Buy their pumps...
It's best to do the walls flat.
And mix small batches:
https://youtu.be/BJZYGY2he1o?si=fv5AhDI8_onA5cVv
Easy-peasy.
Pmullen503 wrote:US Composites has about the cheapest epoxy, slightly yellow but fine under paint. I like Raka or MAS for clear finish.
I'd use 6 oz cloth, you could use 4oz but not to save weight. Saving 5 lbs on a 1000 lb trailer isn't worth less strength and durability.
Pmullen503 wrote:I've used Thayercraft for cloth, but 6 oz cloth is pretty generic, you can get it anywhere .
You don't need a new mixing cup as long as what's left from the previous batch hasn't started to gel. If that's the case, definitely use a new cup.
KCStudly wrote:Use a new cup for each batch. If you mix a 2nd batch in a "hot" cup the pot life will be shortened by the kick of the previous batch. I like to use clear plastic cups because it is easier to see what's going on inside. When you think you've got everything out of the cup turn it over on a dry spot of cloth and you'll get a little more. Set aside and check that it cured right the next day. If you want to bother you can peel the remainder out of the cup and reuse it, at least for the plastic cups... I just use left over dunkin iced coffee cups cut down to size... but it isn't worth the effort or risk of leaving flaky bits of dry to foul the next batch.
When do you suggest replacing the container?
