Fiberglass cloth brand and resin
Postby 23Sojourney45 » Tue Jun 11, 2024 7:25 pm
I just wanted to get an update on what people used for their fiberglass cloth and resin, never worked with it before. I've read the TNTTT thread: "Best fiberglass to use on wood teardrop?" but that thread is from 2016 (Yes, I'm also going to put UV protecting spar varnish) Does that information still hold up? or does anyone have new updates? Get fiberglass cloth, not chopped? I've read that chopped aren't as strong. I was going to check out home depot but I don't think that they have the size that I'm interested in. I'm working on a 5x8 trailer so it has to be at least 5ft wide, but I don't mind going smaller if there's none. If its 4ft, then I would have to figure out how to add the extra 1ft and make it seem seamless if possible. I will not be putting filon or aluminum on it, keeping the wood look for now. I've seen some video too of people using different fiberglass cloth brands and resin. I've looked at amazon and other sites and its a bit overwhelming, I don't want to choose the "wrong" thing, or is that not possible? I'm aiming for 2 oz walls and maybe 4 oz roof, but basically hovering around 2-4 oz nothing more. I don't want to go the route of PMF even though it may be cheaper. Who knows, I may change my mind if the price goes up and up, lol. Any information is welcomed. Thanks in advance. :thumbsup:
23Sojourney45
Re: Fiberglass cloth brand and resin
Postby Tom&Shelly » Tue Jun 11, 2024 7:48 pm
The information from 2016 should still be correct. I think I remember that you don't want to use chopped fiberglass with epoxy, but maybe someone else can chime in to confirm or refute?
I've also heard, but can't confirm that fiberglass is actually just about the same price as PMF. I've never used PMF so don't know.
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Postby tony.latham » Tue Jun 11, 2024 8:27 pm
Most matt is glued together with a substance designed for polyester resin to dissolve. It's not meant to be used with epoxies and I quit using polyester resin a couple of decades ago. Don't use the stuff for a woody.
I have used a few gallons of Raka epoxy. It's good stuff, and their cloth is too. 6 oz cloth is fine for sealing plywood.
Buy their pumps...
It's best to do the walls flat.
And mix small batches:
https://youtu.be/BJZYGY2he1o?si=fv5AhDI8_onA5cVv
Easy-peasy.
Postby Pmullen503 » Tue Jun 11, 2024 9:13 pm
US Composites has about the cheapest epoxy, slightly yellow but fine under paint. I like Raka or MAS for clear finish.
I'd use 6 oz cloth, you could use 4oz but not to save weight. Saving 5 lbs on a 1000 lb trailer isn't worth less strength and durability.
Pmullen503
Images: 67
Postby 23Sojourney45 » Wed Jun 12, 2024 10:37 pm
Tom&Shelly wrote:The information from 2016 should still be correct. I think I remember that you don't want to use chopped fiberglass with epoxy, but maybe someone else can chime in to confirm or refute?
Thanks Tom, at least its relevant. I may change to PMF, who knows lol :R , but right now I'm going to check out Fiberglass.
23Sojourney45
Postby 23Sojourney45 » Wed Jun 12, 2024 10:41 pm
Buy their pumps...
Easy-peasy.
Tony, thanks, I was looking at Raka and Wes and didn't know if there were any other brands out there that people have used. But, for the most part, a lot have used Raka eh? I guess they don't go through Amazon. I will definitely buy the pumps, from what I've seen with the videos and through reading, it does come in super handy. I will remind myself to use small batches. Is there a little bit that is left over in the container after each refill? When do you suggest replacing the container? Again, I don't know if it will start to build up after each refill. In your video, it looks like you were using two cups, is that the key?:thinking:
Last edited by 23Sojourney45 on Thu Jun 13, 2024 12:04 am, edited 1 time in total.
23Sojourney45
Postby 23Sojourney45 » Wed Jun 12, 2024 10:43 pm
Pmullen503 wrote:US Composites has about the cheapest epoxy, slightly yellow but fine under paint. I like Raka or MAS for clear finish.
Pmullen, US Composites? I will have to check them out. I don't mind it turning yellow, if it does what its supposed to do then I don't mind the color, lol. Where do you get your cloth?
23Sojourney45
Postby Pmullen503 » Thu Jun 13, 2024 7:41 am
I've used Thayercraft for cloth, but 6 oz cloth is pretty generic, you can get it anywhere .
You don't need a new mixing cup as long as what's left from the previous batch hasn't started to gel. If that's the case, definitely use a new cup.
Pmullen503
Images: 67
Postby 23Sojourney45 » Thu Jun 13, 2024 7:11 pm
Pmullen503 wrote:I've used Thayercraft for cloth, but 6 oz cloth is pretty generic, you can get it anywhere .
Thanks Pmullen, will definitely check the batch for gelling. :)
23Sojourney45
Postby KCStudly » Fri Jun 14, 2024 6:01 am
Use a new cup for each batch. If you mix a 2nd batch in a "hot" cup the pot life will be shortened by the kick of the previous batch. I like to use clear plastic cups because it is easier to see what's going on inside. When you think you've got everything out of the cup turn it over on a dry spot of cloth and you'll get a little more. Set aside and check that it cured right the next day. If you want to bother you can peel the remainder out of the cup and reuse it, at least for the plastic cups... I just use left over dunkin iced coffee cups cut down to size... but it isn't worth the effort or risk of leaving flaky bits of dry to foul the next batch.
Postby 23Sojourney45 » Fri Jun 14, 2024 1:42 pm
KCStudly wrote:Use a new cup for each batch. If you mix a 2nd batch in a "hot" cup the pot life will be shortened by the kick of the previous batch. I like to use clear plastic cups because it is easier to see what's going on inside. When you think you've got everything out of the cup turn it over on a dry spot of cloth and you'll get a little more. Set aside and check that it cured right the next day. If you want to bother you can peel the remainder out of the cup and reuse it, at least for the plastic cups... I just use left over dunkin iced coffee cups cut down to size... but it isn't worth the effort or risk of leaving flaky bits of dry to foul the next batch.
Thanks KCStudly, I was using plastic cups for my other teardrop essential, lol. I have too many to count, so why not, right? That's a good tip about turning it over, I've seen some videos of people doing that and wondered why. I used the peal and re-use tactic when I was using these cups for titebond, lol. Thanks again. :thumbsup:
23Sojourney45
Postby twisted lines » Fri Jun 14, 2024 4:08 pm
Digging into this soon as well :thumbsup:
Racking up; And Rapin foam
twisted lines
Postby saywhatthat » Fri Jun 14, 2024 10:37 pm
IMG_20220110_163942 s.jpg (42.23 KiB) Viewed 896 times
if you're going to use fiberglass. Why would you use wood what a waste. you can build a indestructible , insulated trailer. If you drop it of a cliff you go to walmart to fix . Beware of dam liars about ploy resin and home depo foam it is the easy way to build you cannot mess up it like a Lego . Pods run under 200 lbs. for 5 by 5 by 10 there is no better way to build a forever trailer. Family trust owns a few RV repair shops is also involved in heavy ballistic components.
IMG_20220129_164311 (1).jpg (38.21 KiB) Viewed 896 times
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby saywhatthat » Fri Jun 14, 2024 10:40 pm
Theirs 2 under 12 years old girls build these
saywhatthat
Images: 135
Postby tony.latham » Sat Jun 15, 2024 12:06 pm
Each batch gets a new container. You'll want to have a stack of these, new mixing sticks and a fresh box of gloves ready to go. It's important to keep epoxy off your skin so you don't develop an allergy to it. And of course, wear safety glasses. :thumbsup:
Users browsing this forum: Bing [Bot] and 6 guests
