Fan and roof thickness issue
Postby 23Sojourney45 » Tue Jul 09, 2024 1:00 pm
Has anyone had this issue? I bought a fan vent through amazon and the description says that its recommended roof thickness: 37-85mm. When I received it and took it out of the box, I looked at the gap between the inside trim and the fan, and its too much. Mind you, this is the way it came in the box. What I mean by the "inside trim" is the part that goes inside the cabin and up into the fan housing, its the part that you screw into your ceiling. Well, I took out the fan out of the box to see if there was anything blocking the inside, nope. :x It literally sits on the inside part of the fan at 2 3/4 inches or 69.85 mm as its shortest. The description says that its recommended for 37mm -85mm roof thickness. My roof/ceiling thickness is 1 3/4 inches. Have any of you encountered this problem? did you simply cut off the inside trim to fit your ceiling? Its plastic and I don't know how i'm going to trim all 4 edges so that it doesn't crack. My wife and I tried flipping it over and that will work, BUT the trim part that goes inside the housing is now facing down towards the cabin floor. Obviously if we left it this way we would hit our heads on it since its sticking out. I've posted the link from amazon. I could return it and get another one but I wanted to know what you guys thought. It seems like a great fan and I wouldn't want to return it, but if I have to, I will.
https://www.amazon.com/Reversible-Exhua ... 9tdGY&th=1
23Sojourney45
Re: Fan and roof thickness issue
Postby twisted lines » Tue Jul 09, 2024 1:47 pm
Looks like a nice fan;
Mine is near 6" tall & need's cut to fit.
Havant done it yet but will soon :thinking:
Racking up; And Rapin foam
twisted lines
Postby 23Sojourney45 » Tue Jul 09, 2024 1:52 pm
twisted lines wrote:Looks like a nice fan;
I contacted the company and they replied with the smallest they have is 3 inches. But, the amazon site says 37mm (just under 1.5 inches)lol. I'm debating still on whether to cut it (how? jigsaw? may crack since I don't have a grinder) :thinking: . I'm also looking for ones that have a smaller gap.
23Sojourney45
Postby Onajourney » Tue Jul 09, 2024 1:55 pm
You need to simply cut the inside trim to your required height. The fan has a lip on the inside so you get some wiggle room. Not sure the directions did'nbt show this unless, like me, threw them out.
Onajourney
Images: 181
Postby 23Sojourney45 » Tue Jul 09, 2024 3:55 pm
I forgot to attach a couple of pictures of the thickness.
shortest gap, its not 37mm
biggest gap, give or take
23Sojourney45
Postby 23Sojourney45 » Tue Jul 09, 2024 3:56 pm
Onajourney wrote:You need to simply cut the inside trim to your required height. The fan has a lip on the inside so you get some wiggle room. Not sure the directions did'nbt show this unless, like me, threw them out.
The directions were simple and to just put the fan ventilation flange up into the main fan and screw. No mention of anything else not fitting or cutting to size. :thumbdown:
23Sojourney45
Postby foxontherun » Wed Jul 10, 2024 2:18 pm
I know this isn't the same brand fan but perhaps these instructions for maxxair fan might help (see step 6).
https://library.maxxair.com/wp-content/ ... 1-2017.pdf
I have the 5100k model and I don't recall how I cut it for sure but I think I used my Jigsaw going really slow and it worked for me. However, I am not 100% sure as this was several years ago and my memory isn't very good, ha! I would think a small trim hand saw (ie coping saw) might work. The cut edge fits up inside the fan box and my cut did not show.
Best wishes,
Harry :)
viewtopic.php?f=42&t=72881
foxontherun
Images: 91
Postby tony.latham » Wed Jul 10, 2024 3:34 pm
I just replaced the trim ring on my Fantastic fan. I had cut off 3" of it. My jigsaw worked fine.
Postby 23Sojourney45 » Wed Jul 10, 2024 6:41 pm
foxontherun wrote:I know this isn't the same brand fan but perhaps these instructions for maxxair fan might help (see step 6).
Best wishes,
Harry :)
@Foxontherun, thanks for the pdf, how detailed are those instructions? lol. Mine didn't come with anything like step 6 suggested. No mention of cutting anything to size until I reached out to the company and they said "trim it." I do have a jigsaw (don't we all teardrop builders? lol), but I also have a hand held manual saw like in the picture. Now, I can start cutting/trimming.... :twisted: Thanks again.
23Sojourney45
Postby 23Sojourney45 » Wed Jul 10, 2024 6:43 pm
tony.latham wrote:I just replaced the trim ring on my Fantastic fan. I had cut off 3" of it. My jigsaw worked fine.
@Tony.latham, another vote for a jigsaw! O.k, jigsaw it is, thanks Tony!! :thumbsup:
23Sojourney45
