myjeepcherokee wrote:Hey guys, so I'm starting teardrop #2, starting to gather up tools already...and it looks like I'm going to need some clamps! Anyone know where I can get say 20 or so for a good price? Home depot had a 2 pack of 12in quick grips for 20 bucks...but I'd like to stay a little cheaper than that!
Mightydog wrote:Bledsoe3,
That's when I usually throw down a piece of 3/4" ply on top of it and back my car on to it.
Ken A Hood wrote:I've seen PVC pipe used as well..... I think it was on here; all you need to do is cut some 1-2" rings and then cut a piece out; just a bit smaller than the thickness your clamping up
Ken A Hood wrote:
PVC Clamps
Materials
3-inch Schedule 40 PVC pipe scrap
Directions
Cut pipe about 1" wide, then slice it once to form clamp. The wider you make the clamp, 2-inches for example, the stronger the clamp. You can make clamps from 2-inch pipe, on up. Ideal for shop, hobby, home, whatever.
you can make a cool tater-gun outa it also, i went with stell though,,,
johnp
And some more uses;
More PVC projects
