Rookie mistake I knew better
Postby Woodbutcher » Tue Aug 29, 2006 8:48 pm
Well I got so caught up in putting on my outside first layer roof I did not pay attention to my buried wires. I figured I better check the wires before I closed up the roof with the final skin. I ran 110 through the wires and sure enough I stapled right into my roof vent wire. It made a nice pop, as you can see from the burnt wire. So I had to tear into my new roof and fix it. I put a wood patch over my repair and will sand it in the morning when I put on the final skin. At least I can cover my dumb mistake and only you guys will know.
Woodbutcher
Postby madjack » Tue Aug 29, 2006 8:51 pm
..better to find it now than latter...like at the campground, when you hoook up...let this serve as a warning to others to ALWAYS mark where your wire runs and other sensetive stuff are located....
madjack 8)
Postby Ma3tt » Tue Aug 29, 2006 9:15 pm
Good thing it wasn't ALIVE!!!!
Be Good
1967 Siesta del Sobrino "Standy"
If you lived here... you would be home by now.
http://www.Camp-Cook.com
Ma3tt
Dutch Oven GURU
Images: 179
Postby tonyj » Tue Aug 29, 2006 9:45 pm
Damn! Damn! Damn!
But like MJ said, better now than later. Easier to fix now, and could have been disasterous out camping.
tony
tonyj
Images: 160
Postby EZ » Tue Aug 29, 2006 9:47 pm
Wirebutcher, I put a nail from the air nailer through a 12 volt line. Killed one of my lights and one that was yet to be installed. Just blew the fuse. I can get around it by tapping into another run but I am not happy.
:cheerswine:
Ed
EZ
Images: 72
Postby Arne » Wed Aug 30, 2006 4:06 am
I try to keep all wire runs straight, either up or across, and make a simple map with measurements I stick on the garage wall. I can never quite remember where the runs are, but the diagram helps a lot.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby asianflava » Wed Aug 30, 2006 4:12 am
If the wire isn't damaged too badly, you may be able to still use it if you can manage to pull the brad out.
asianflava
Postby mikeschn » Wed Aug 30, 2006 4:42 am
Photos of your wire runs help too! Paste a photo or two up on the garage wall, and it'll always keep you thinking... :thinking:
Postby Arne » Wed Aug 30, 2006 10:45 am
A/F has a good point. if the staple is the only thing making contact, just pull it out... unlikely the point of a staple would push the copper wire through.
Arne
Mr. Subject Line
Images: 96
Postby Woodbutcher » Wed Aug 30, 2006 12:27 pm
I did pull the staple out and it worked fine then. But I separated the wires and taped up each side. The sad part was I was looking right at the wire sticking out as I went over it with the staple gun. I managed to miss all the other buried wires. I only have a few spots where I run through the roof ribs. I guess I can only do one thing at a time.
:cry:
Woodbutcher
Postby Mightydog » Wed Aug 30, 2006 1:02 pm
Woodbutcher wrote::cry:
At least you weren't are out in the woods, having turned out the light and are laying there enjoying the sounds of the night when Mrs. Butcher asks, "...do you smell smoke?"
Mightydog
Postby angib » Wed Aug 30, 2006 4:51 pm
I find my ability to think I'll know where things are before putting a skin on and my ability to not know where they are once I've put the skin on to be amazing.
I constantly believe that I have learnt from this experience and won't be so stupid again.
Until the next time........
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Jiminsav » Wed Aug 30, 2006 8:13 pm
I learned not to put wires inside walls and roofs..I'll run wires last and hide them the best I can, but they will be repairable if need be.
Jim in Savannah
Jiminsav
Images: 40
