Caulk?
Caulk?
Postby Stephen G. » Wed Oct 04, 2006 10:44 pm
Hello
Does anyone know where to get caulk that looks like aluminum?
Thanks for your help
Stephen G.
Postby CHUCKLEHEAD69 » Wed Oct 04, 2006 11:07 pm
no sure don't, but is clear out of the question?
JUDE ------- "Laissez les bons temps rouler. let the good times roll"
CHUCKLEHEAD69
Images: 58
Postby Stephen G. » Wed Oct 04, 2006 11:26 pm
No but it would be a plus if it could be found.
Stephen G.
Postby sdtripper2 » Wed Oct 04, 2006 11:28 pm
Stephen:
Sealant Aluminum ... Airstream trailers uses:
http://www.inlandrv.com/articles/vulkem072001.htm
More brands:
http://tinyurl.com/faugo
http://tinyurl.com/jv6hm
sdtripper2
Search Garoux
Images: 168
Postby Nitetimes » Thu Oct 05, 2006 12:07 am
Check HD Lowes for gutter sealer. It can be had in white, silver and I think black and brown. It's slimy stuff but it will seal about anything.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Stephen G. » Thu Oct 05, 2006 12:13 am
I need more for cosmetics than anything. It would make some of the seam areas I will have look cleaner.
Stephen G.
Postby Podunkfla » Thu Oct 05, 2006 1:17 am
I like to use "PL Urethane Gray" ... Most big-box stores have it. It is also sold as gutter sealant. It isn't silver like aluminum, but it is pretty close and works good with alum. trim. It seals extremely well and holds up even exposed to sunlight. I've also used it for skylights and chemney flashing on houses for years... best I've found.
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby madjack » Thu Oct 05, 2006 1:29 am
Sikaflex 221 sealant, available from http://www.austinhardware.com/product.a ... %5Fid=3243 is an excellent urethane sealant and comes in white/black/grey...a lot of "gutter" sealant is butyl rubber which is an excellent sealer but it is slimy and will "squish" out of a joint for weeks before it finally sets up.....
madjack 8)
Postby Podunkfla » Thu Oct 05, 2006 2:32 am
Yeah, you are right Jack... I was thinking I had seen some urethane gutter sealant; but I think you are correct that it is butyl rubber. We used to use that gooey stuff years ago putting windows in custom vans. Yucky stuff to work with. :o
<B>~ Brick
Podunkfla
ol' noodle haid
Images: 5
Postby madjack » Thu Oct 05, 2006 2:42 am
Brick, we tried a number of sealant products...we started with "Evil Black Stuff"(auto windshield sealant/adhesive) then switched to butyl rubber and thought it was "THE STUFF"...a week later and it was still oozing out from behind trim and we named it "Most Evil Grey Stuff" and went back to the urethane(at least it sets up)...will probably use the Sikaflex221 grey on future builds unless we can find a grey urethane in the local stores here in Pohdunk La.
madjack 8)
Postby 48Rob » Thu Oct 05, 2006 6:59 am
I don't recall the brand, but Lowes carries silicone in "aluminum" that matches perfectly with mill finish aluminum.
Rob
48Rob
Postby Sonetpro » Thu Oct 05, 2006 7:26 am
48Rob wrote:I don't recall the brand, but Lowes carries silicone in "aluminum" that matches perfectly with mill finish aluminum.
Rob
That's what I used. It is the same color as the trim. Almost invisable. I didn't like the butyl gutter seal I tried that first.
Sonetpro
Images: 107
Postby BILLYL » Thu Oct 05, 2006 10:48 am
The stuff is made by GE - and made for sealing up AL and stuff like that. Got it at Lowes.........
Bill
"If your children ever find out how lame you really are, they'll
gonna murder you in your sleep...." Frank Zappa
BILLYL
Postby Stephen G. » Sat Oct 07, 2006 1:34 am
Thanks everybody :thumbsup:
Stephen G.
