b.bodemer wrote:Jim,
I think you'll get a lot of responses here................
I decided to go with a Austin Hardware draw pull keyed in pairs. I haven't installed them yet but feel they are going to work great, tighten in my hatch just enough and I only have to use one key. I can wrap it around the side wall to the hatch and use it at 90 degrees.
If you go with something keyed make sure you tell the salesperson you want them "keyed in pairs".
Product Number: AH RN232000-01 ZNPR
Barb
b.bodemer wrote:I decided to go with a Austin Hardware draw pull keyed in pairs. I haven't installed them yet but feel they are going to work great, tighten in my hatch just enough and I only have to use one key. I can wrap it around the side wall to the hatch and use it at 90 degrees.
halfdome, Danny wrote:Austin Hardware has lots of different latches but these in the photo shouldn't be used for security purposes since all it would take is the removal of two screws to get in. I went with latches without locks.Danny
Danny
Endo wrote:Danny
I used the same latches. You can very easily make them more secure by using screws with "one way heads".
I was able to attach mine to the 1/8" aluminum trim on my hatch with pop rivets.
Ken A Hood wrote:You have to be careful if you plan on using the tamper proof screws, "if" you ever need to replace/fix the latch you'll need to drill out the screw.....
