Help With Hatch Latches
Postby John6012 » Sun Nov 12, 2006 11:33 am
I bought the hatches from Grant at Lil Bear and can't figure out how to mount them. I have the aluminum strips on both sides and bottom of my hatch, (the ones that you can cover up the rivets with slide-in vinyl trim). My question is, would you recommend a "notch" cut out of the aluminum trim? That is, cut off the outer edge so the clip will fit solid and flat? Thanks
John6012
Postby dhazard » Sun Nov 12, 2006 10:09 pm
John, notch the trim and let your hinge overhang the side of the trailer about ¼”. Can somebody post a pic?
Many miles and many tears. Times were hard but now they're changing.
You should know that I'm not afraid.
dhazard
Images: 122
Postby John6012 » Sun Nov 12, 2006 11:09 pm
Thanks Dhazard. I was planning on notching or cutting out the "edge trim" and mounting the clip flat on the aluminum trim. But I'm not quite sure what you mean by allowing the hinge overhang the hatch 1/4". Probably you mean the latch exending 1/4" beyond the hatch of the trailer? Or the clip extending 1/4" beyong the edge of the aluminum trim? The hatch hinge is overhanging the cabin/body by 1/4". Thanks a lot, I appreciate your response. John
John6012
Postby dhazard » Mon Nov 13, 2006 12:59 am
John, over the side of the body to allow the rain to run off and not down the side of the trailer. Regards Dan
dhazard
Images: 122
Postby John6012 » Mon Nov 13, 2006 8:58 am
I'm sorry. I still don't get it. Cut off the outter edge of the trim and mount the latch clip flat on the trim? Thanks
John6012
Postby CHUCKLEHEAD69 » Tue Nov 14, 2006 7:47 am
i think y'all are on two different Page's you're are talking about a hatch latch and dhazzard is talking about a hatch hinge. cant help on the latch problem though
JUDE ------- "Laissez les bons temps rouler. let the good times roll"
CHUCKLEHEAD69
Images: 58
Postby John6012 » Tue Nov 14, 2006 9:28 am
I think you're right. I am talking about a hatch latch.
John6012
Postby Kevin A » Tue Nov 14, 2006 9:55 am
John,
Can you post some photos of what you're working with? It might help if we can see it.
Kevin A
The other guy
Images: 289
Postby John6012 » Tue Nov 14, 2006 9:05 pm
Sorry, I don't have a digital camera. Been meaning to get one but my sone will be up Thanksgiving and hopefully he'll bring his. Meantime, I think I'll use the dremel tool to cut out the outer edge of the aluminum trim and mount the clip on with rivets, then go for the latches themselves.
Thanks and if I mess it up, I'll have my son take a picture.
John6012
Postby dhazard » Wed Nov 15, 2006 12:07 am
So sorry :o :oops:
dhazard
Images: 122
Postby John6012 » Wed Nov 15, 2006 9:49 am
Not to worry, Dhazard, your heart was in the right place. Beswides, it's the thought that counts. You're the only one that responded except the admin. Thanks and have a filling Thanksgiving!
John6012
