Heat lamp?
Anything electric, AC or DC
Heat lamp?
Postby Tripmaker » Fri Nov 17, 2006 5:01 pm
I'm in the process of wiring and have installed two aircraft type 12V reading lights. When testing them I found they do generate some heat to the rear as well as the front. I plan to leave about 2" around the lights with no insulation but I am concerned that when have the roof skin on that this heat could be a problem in such a small area as there is no place for the heat to vent or disapate. Is this, or is it not, something to be concerned about? It feels hot to me but maybe it's not hot enough to cause a fire or other problem. I don't know.
I saw in another thread that there are LED replacements for some incandecent bulbs. Does anyone know of a LED replacement for an 1139 bulb?
Jim
Tripmaker
Images: 59
Postby goldcoop » Fri Nov 17, 2006 5:45 pm
Tripmaker-
Heat generated is a real worry!
How about making a separate small enclosure with vents. basically making a surface mount light?
Then you can fully insulate the roof and just drop wires thru the ceiling to the enclosed light box...
Also if you wanna change the light at some point you wont have a hole in your ceiling!
Cheers,
Coop
goldcoop
Images: 32
Postby Kurt (Indiana) » Fri Nov 17, 2006 5:50 pm
http://www.tjtrailers.com/store/product5877.html
The above web site has lots of different wattage bulbs to offer. If the heat is too high, maybe a lower wattage bulb would be better. Seems like the #1139 has the same post as come of the smaller bulbs and would be enough light to read with. I know I put lowwer wattage bulbs in mine simply because they were way too bright. I was using two #1156 bulbs and switched to (orange) bulbs. I don't know the number, but they are much better than the real bright ones. There is plenty of light for reading with the smaller wattage.
CRA2023 Web Site
"Wall of Fame 2011-2021"
Kurt (Indiana)
Images: 178
Postby Tripmaker » Fri Nov 17, 2006 5:52 pm
I already have them installed. They are located in the front wall about 24" up from the floor, above where our heads will be when lying down.
I know others have used these lights. What have you all done about heat? If anything.
Jim
Tripmaker
Images: 59
Postby Tripmaker » Fri Nov 17, 2006 6:06 pm
Hey Kurt, how's it going?
The link you posted has the 1139 like I have, it's a 12 watt bulb. Do you know if there a designation for the base so I can match it with a lower wattage bulb or perhaps an LED? I know what you mean about brightness, once the eyes get used to lower light levels it doesn't take much to see.
I read that you organized a TD meet last spring at Spring Mill. Any plans to have one in 2007? I should be ready for a shakedown cruise.
Jim
Jim
Tripmaker
Images: 59
Postby Kurt (Indiana) » Fri Nov 17, 2006 6:49 pm
Jim, No formal plans yet but keep your eye on the "Midwest" gatherings.
The #1139 looks like Fig. "F" in the pictures. If Fig. "C" is the same base then #89 might be better for less light and heat.
BTW, You're on the mailing list for the Midwest Gatherings so you'll be kept up to date as plans develop.
CRA2023 Web Site
Kurt (Indiana)
Images: 178
Postby Sonetpro » Fri Nov 17, 2006 7:00 pm
I thought about the heat also. I didn't put insulation where they mount. You can see in the pic where I put a backing plate to mount them to, Without insulation. I also bought a light with a high and low.
Sonetpro
Images: 107
Postby bledsoe3 » Sat Nov 18, 2006 9:55 am
I built mine out using matching wood from my cabinets.
bledsoe3
Images: 112
Postby Tripmaker » Sat Nov 18, 2006 7:25 pm
Sonetpro...that's what I planned to do but is the heat traped in there a problem?
bledsoe...that looks good but isn't the heat still trapped behind the lights? Maybe what seems hot to me by touch isn't enough to worry about.
Kurt... I will try a smaller bulb to see if that helps. Thanks for putting me on the mailing list. I'm looking foward to a TD meet.
Jim
Jim
Tripmaker
Images: 59
Re: Heat lamp?
Postby Podunkfla » Sat Nov 18, 2006 8:15 pm
Tripmaker wrote:I saw in another thread that there are LED replacements for some incandecent bulbs. Does anyone know of a LED replacement for an 1139 bulb?
I have some I got from CustomDynamics.com that are very high quality and bright. The mostly market to the motorcycle market (?) but, I have them in my PU taillights & signals too.
http://www.customdynamics.com/motorcycle_led_bulbs.htm
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby bdosborn » Mon Nov 20, 2006 10:50 pm
Here's a replacement lamp that might work
You can get it here.
Its designed as a replacement for incandescent lamps in RV lights.
Images: 806
Postby Laredo » Mon Nov 20, 2006 11:05 pm
"Backplate" them with reflective material, then cover that with a fabric grille. If you want to get fancy, you can put a tiny little computer fan (Ice Chip) behind the grille as well.
Laredo
Postby ARKPAT » Tue Nov 21, 2006 1:32 am
I know they are not cheap but retro - fit a fixture you can try the C. Craine L.E.D.s bulbs.
There are several other L.E.D. replacement lights that are mentioned elsewhere in the forum. Check Here in the listing at the top of this page.
Pat
Life is to short always eat dessert first.
ARKPAT
Images: 77
Postby coreyjhen » Tue Nov 21, 2006 12:02 pm
Here's a direct replacement: http://www.ledtronics.com/ds/B606/
You probably want either the 3000K or 8000K, which are the equivalent of a normal 120V cool white or standard bulb, respectively.
"They laughed at Columbus, they laughed at Fulton, they laughed at the Wright brothers. But they also laughed at Bozo the Clown." - Carl Sagan
coreyjhen
Images: 9
Postby bdosborn » Tue Nov 21, 2006 11:40 pm
coreyjhen wrote:Here's a direct replacement: http://www.ledtronics.com/ds/B606/
8000K is fairly blue and 3000k is yellowish. For comparison, a cool white fluorescent is 4100K and a warm white is 3500K. I have both colors of LEDs and greatly prefer the 3000K.
Images: 806
Return to Electrical Secrets
