BrwBier wrote:Fresh water tank and gray water tankEach holds about 7 gallons
Micro469 wrote:BrwBier wrote:Fresh water tank and gray water tankEach holds about 7 gallons
Are those going to be accessable if something goes worng???
surveytech wrote:Bob........that was a short stay in Lakeland!
BrwBier wrote:It will pump down to about the last 1/2 gallon. There is also a drain for the fresh water for the end of trip, and when parked level, drains about 95% of the water. Its the same for both tanks. I had thought about a pressurized system but then you would have to seal the fill valve and I only want to use a pour in type valve. This will be mounted inside of a lower cabinet.
stedi wrote:well if i ain't God's own thread killer!
