Td frame weld up 5' x 10'
Postby legend lime » Tue Dec 12, 2006 8:31 pm
Hi All
I am new to this form, here are some pics of the TD frame I just completed welding up I ordered the axel today it should be here the 18th just in time to install over the Holidays. The TD body will be 5' X 10'
the axel is a Dexter #9 2500 lb high profile with 45 degrees down and 15" tires 5 on 4 1/2. I am trying to get the TD to be leval with my SSR pick up when it's being towed. after working with the lady at Dexter she said this would work the best with the hitch hight I have. Hope I have posted the pics correctly this form is differant from some I ve been on.
edit: I placed img tags around your links... looks great! Also welcome to the forum! :)
New Pics;
The wheels and tires are from an 05 Mustang that I sold to get the 05 SSR that I now have and will use to pull the TD.
Image[/img]
Legned Lime, Acworth, GA
legend lime
Images: 252
Postby weasel » Tue Dec 12, 2006 8:55 pm
Welcome and thats a nice lookin' frame. Mines close to that style.
weasel
Postby legend lime » Tue Dec 12, 2006 9:52 pm
weasel what ever you did the pics won't open now
legend lime
Images: 252
Postby cuyeda » Wed Dec 20, 2006 3:14 am
Nice frame! Is that PVC through the frame? I am guessing it is for wiring.
When you welded the pieces together, how did you keep the frame level/square. Did you weld it on the ground or on a workbench?
Cliff & Vanessa
cuyeda
Postby legend lime » Thu Dec 21, 2006 3:56 pm
Cuyeda
Yes the PVC is for wiring, as for the welding I built frame work off of a set of saw horses using 2"x 10" boards I had left over from a porch rebuild. As I was building the frame work I made sure it was completely level then when I cut out each piece I used clamps to secure it to the table before I welded it togeather. I picked up my axel Monday from Dexter Axel and I hope to get it welded in this weekend still haven't decided on the wheels and tires yet. I went with 5 on 4 1/2 hubs and I will either run 14" or 15' wheels. The people I talked to at Dexter were very helpful in getting the axel built the way I wanted it. the Hitch on my SSR is 18 1/2" off the ground and I told the Lady that I wanted the trailer to be as level as possible; she said that I would need a 45 degree down and run either 14 or 15" wheels and tires. As soon as I get it welded in and the wheels and tires on it I'll post more Pics.
legend lime
Images: 252
Postby prohandyman » Sat Dec 23, 2006 1:02 pm
Legend
How much do you think you will have in frame and axle?
Comparing the cost vs. buying a complete frame
Thanks :thinking:
Dan
prohandyman
Images: 785
Postby legend lime » Sat Dec 23, 2006 6:27 pm
prohandyman
I just completed the frame today and with steel, axel, front coupler, and front jack I have a total of $384.00 in it. I'll try and post some pics here later tonight.
legend lime
Images: 252
Postby asianflava » Sun Dec 24, 2006 2:52 am
legend lime wrote:prohandyman
That doesn't include wheels and tires does it? I found those to be one of the more expensive parts, even though I used pip-squeak 175/75-14s.
asianflava
Frame
Postby legend lime » Sun Dec 24, 2006 9:37 pm
asianflava
Your right that's with out the cost of the wheels and tires, but even if I put $500.00 in wheels and tires (which I don't think I will have to)I still only have $884.00 in it and the frame is built the way I want it rather than buying someone elses trailer and then having to modify it to fit the trailer I am building.
legend lime
Images: 252
Postby Big Dave » Fri Jan 05, 2007 8:14 pm
Legend, that's almost exactly what I was had in mind. Are the mounting tabs past where the triangle joins the frame for a storage box or will the camper overhang that portion? Also, does it overhang he rear also? How long does that front triangle end up being?
Alright enough with the questions, I'm just excited to see pictures of what I have been daydreaming about for months. :oops:
Big Dave
Postby mikeschn » Sat Jan 06, 2007 6:01 am
Lime,
That's pretty much where I had the dropped floor on the Lil Diner. It worked out well!
