Time To Glue And Screw The Walls To The Floor...Question?
Postby sandman » Wed Jan 31, 2007 3:16 am
Hey Guys,
I am slowly making some progress on my teardrop/cycle hauler. I am ready to finally glue and screw the walls to the floor. Just wanted to find out what you teardrop pros use to glue the walls up. I have Liquid Nails Heavy Duty Construction Adhesive, Gorilla Glue, or Titebond III as my choices. What would you use to ensure the best install??
sandman
Images: 154
Postby madjack » Wed Jan 31, 2007 3:27 am
...with screws in use, they would all probably work but the Liquid Nails product, if you are coming down over the steel frame would probably be my first choice...
madjack 8)
Postby MOKI SEAKER » Wed Jan 31, 2007 9:02 am
I agree with MJ on that one, Liquid nails. 8) Jim G
Mark Twain
MOKI SEAKER
Images: 41
Postby SteveH » Wed Jan 31, 2007 11:21 am
I would think epoxy would be the best, but also the most expensive and the most trouble. With that said, I used Titebond II and the walls have not fallen off yet.
SteveH
SteveH
Images: 42
Postby TRAIL-OF-TEARS » Wed Jan 31, 2007 3:33 pm
Might also depend on how you attach the side wall to the floor. I used screws and TB III. This is how I did it.
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
Postby Mary K » Wed Jan 31, 2007 5:00 pm
I used Titebond III, BUT if my tube of Liquid Nails was not half dried up I would have used it.
I hate trying to seal those tubes back up :fb !!
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby fornesto » Wed Jan 31, 2007 5:31 pm
Mary K wrote:I used Titebond III, BUT if my tube of Liquid Nails was not half dried up I would have used it.
Mk
Just drive a 2" screw into the open end. When you need it open, just back out the screw.
fornesto
Postby Mary K » Wed Jan 31, 2007 5:52 pm
Mk
DUH :duh :duh:
I Should have thought of that!!! Thanks :thumbsup:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby sandman » Wed Jan 31, 2007 10:41 pm
Thanks for the replies everyone. Liquid Nails it is then. I bought two tubes of it and was hoping it would work. About to get those walls glued up. I now know what Teardrop time is...lol. :lol: It takes forever to build one if you're slow like me. I have to think and re-think everything before actually doing it.
I have received all my light fixtures and just order my fuse panel/converter to run all my electrical.
sandman
Images: 154
Postby Podunkfla » Wed Jan 31, 2007 11:21 pm
Mk
DUH :duh :duh:
Mk
A large electrical wire-nut (grey) works even better to seal open caulk tubes. 8)
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby madjack » Wed Jan 31, 2007 11:52 pm
Podunkfla wrote:
Mk
DUH :duh :duh:
Mk
...tis what I use and it works a charm!!!!!!!! :thumbsup: ............................ 8)
Postby Miriam C. » Thu Feb 01, 2007 12:33 am
madjack wrote:
Podunkfla wrote:
Mk
DUH :duh :duh:
Mk
Well I have play Dr gloves so when I finished I just put a finger over the end, and flipped the glove off and on to the glue. Little finger works great and the glue keeps it on. 8)
Postby Nitetimes » Thu Feb 01, 2007 12:40 am
Miriam C. wrote:Well I have play Dr gloves so
You wear gloves when you play Dr.?? Seems like that would take some of the fun out of it to me. 8) :lol: :lol: 8) 8) :lol: :lol: :lol: :? :? :? :?
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Miriam C. » Thu Feb 01, 2007 12:50 am
Now how am I gonna say that so it gets better instead of worse. :oops: Fake gloves-----no
Fake Dr---- :roll:
:lol some days....Guess how cold it is out. Is it snowing again? I think I was out in it too many times. Brain freeze.
Postby sandman » Thu Feb 01, 2007 2:48 pm
Well, it looks like I am committed to build the Teardrop now. I just glued and screwed up my first wall to the floor. My hands were shaking while I was applying the bead of Liquid Nails to the floor. There was no turning back so I just went with it and installed my first wall permanently. Feels strange knowing I can't remove it now. :) The install went without a hitch. I put several braces on it to keep it square and installed a few roof spars to hold it all together. Once the liquid nails has cured, I will be gluing up wall number two tonight. I am on my way!!!
sandman
Images: 154
