Miriam C. wrote:Oh yeah if your using a circular saw (skill type) you will need to clamp it down because it really doesn't provide much resistance and will probably shoot out. Trust me they can get some distance on them.
Long sleeves, high collar and safety glasses
Arne wrote:I'd almost try a skil saw with a straight edge instead, with the foam marked every 1.5 inches.
Mary K wrote:Arne wrote:I'd almost try a skil saw with a straight edge instead, with the foam marked every 1.5 inches.
Thats my plan... couple of weeks before I get to that point, let you know how it goes!!!
Mk
Mk
Arne wrote:I've been toying with this... kerfing a 4 ft wide piece of foam, or even a 2 foot wide piece accurately every 1.5 inches would be a real pain....
bobhenry wrote:Mary K wrote:Arne wrote:I'd almost try a skil saw with a straight edge instead, with the foam marked every 1.5 inches.
Mk
go buy a 2x4 or 4x4 piece of pegboard insert 2 10 d finish nails thru the last row of holes top and bottom drive the nails thru the foam to hold it to a piece of plywood under your foam. Set your circular saw at 1/4" or 1/2" or whatever make a pass using the peg board edge as a guide. Shift 1 hole and repeat. By moving the nails once or twice it would be easy and fairly quick to do an entire 4x8 sheet of foam. Offset the nails 1/2" from the original start point and you could go back thru again and have every 1/2" if needed. If the shoe of your saw tries to jump the edge of the peg board , screw a piece of 1x2 to it. When your done you can have a new tool board.If you put foam behind the tool board on the wall the hooks will go in without hitting the wall studs and the board won't bounce and spit off your hooks either. Anyone near Frankfort Indiana that wants a pickup load of window cut out scrap 1/2" or 3/4" dow blue foam P.M. me. We give it away as scrap after we sheath the wall panels and cut out the windows and doors with the routers. Anyone near a wall panelizer just call they all have to get rid of window and door cut outs generall free and glad to get rid of it.
Classic Finn wrote:bobhenry wrote:Mary K wrote:Arne wrote:I'd almost try a skil saw with a straight edge instead, with the foam marked every 1.5 inches.
Mk
Thats some great advice..![]()
Classic Finn wrote: Thank You, Gee I live so far away from Indiana it hurts...![]()
Classic Finn
