Door Handles & Latches..To close to edge.
Postby Keith B » Wed Mar 07, 2007 6:49 pm
Excellent idea on the lock.. thats use'n the ole melon... thanks for tip.
Keith
"Work and work and do your best! Paint and putty will do the rest!"
Keith B
Postby sdtripper2 » Thu Mar 08, 2007 1:03 am
Rob:
I have been wondering how do make a lock .... and this idea seems perfect.
Rob, Am i right thinking that the strap is to wrap around the inside handle in some way to hold the pin in place, or is the pin snug enough and the strap is just a handle of sortsImage
sdtripper2
Search Garoux
Images: 168
Postby 48Rob » Thu Mar 08, 2007 7:57 am
Hi Steve,
The strap is just to make it easy to hold the pin/remove the pin in the dark from the lock...a handle of sorts.
The pin is just slightly snug in the hole.
The hole is drilled through the front, and back of the steel case, and into the wood behind it by another 1/2".
Once inserted, the pin won't fall out.
Rob
48Rob
Postby 48Rob » Fri Mar 09, 2007 2:27 pm
These pictures may explain it better than I can...
<img src="http://img.photobucket.com/albums/v284/1948rob/Cabin%20car%20project/pin.jpg?t=1173468070"><P>
<img src="http://img.photobucket.com/albums/v284/1948rob/Cabin%20car%20project/pin2.jpg?t=1173468235">
Anybody know what I made the pin out of?
(First hint is RR...)
Rob
48Rob
Postby Platbiker » Fri Apr 27, 2007 1:04 am
looks like backpack frame clevis pin to me....
Platbiker
Postby Denny » Fri Apr 27, 2007 12:17 pm
Would that be from the IC or TP&W?
Build pics: http://community.webshots.com/user/drshop
Some things are just cooler'n h*ll!
Denny
Images: 29
Postby Stevebaz » Fri Apr 27, 2007 2:58 pm
telephone pole inspectors nail.
Stevebaz
