Another @*%! Air Conditioner Question
Postby caseydog » Tue Mar 20, 2007 6:03 pm
Okay, I bought this $99 AC form Sears, and now I gotta figure out how to mount it in my Little Guy, or take it back.
find sears clicky
One idea, that puts it out of my way in my small sleeping quarters, is to mount it though the bulkhead wall between the cabin and galley. But then, I would need to vent the galley for heat to escape with the lid down. I only plan to use this AC to sleep. I won't be in the cabin much during the day, unless the weather forces me inside.
Another option is through a wall, but I'm not crazy about that.
Will the heat from this thing be too much for the galley? Will I need huge vents for that heat? Am I nuts to even try this thing?
CD
My build journal is HERE
caseydog
Images: 515
Postby Chuck Craven » Tue Mar 20, 2007 7:05 pm
Set the AC on the ground next to the TD. Make a sheet metal duct over the AC’s cool air output. Then use a 4” drier flexible duct to a hole in the floor or through the galley bulkhead. That way in the spring or fall when it is cooler you don’t have to carry it along.
If you search there is several that have done it that way and have posted pictures. 8)
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby Jiminsav » Tue Mar 20, 2007 7:54 pm
CD,make a second door away from where you normally sleep and mount the A/C to it, and when you need it, just change doors.
Jim in Savannah
Jiminsav
Images: 40
Re: Another @*%! Air Conditioner Question
Postby sdtripper2 » Tue Mar 20, 2007 8:53 pm
caseydog wrote:Okay, I bought this $99 AC form Sears, and now I gotta figure out how to mount it in my Little Guy, or take it back.
find Sears here Clicky
CD
caseydog:
A/C is an subject that has lots of ideas.
Here are a few that may help you think inside and outside the box?
Get the A/C in cause in the summer you will thank goodness you got it.
Here are some novel Ideas of the past:
Side tent air conditioner idea
http://tnttt.com/viewtopic.php?t=9499
Two door method swing out A/C & set on ground and one pipe hole in:
http://tnttt.com/viewtopic.php?t=5136
Tongue & front install:
http://tnttt.com/viewtopic.php?t=12116
http://tnttt.com/viewtopic.php?t=9041
Rear type install:
http://tnttt.com/viewto ... 603#150603
Bob Osborn's in and out window install
http://tnttt.com/viewto ... 157#115157
Hide away A/C
http://tnttt.com/viewtopic.php?t=7084
sdtripper2
Search Garoux
Images: 168
Postby Chuck Craven » Tue Mar 20, 2007 9:09 pm
This is what I like, Mary K's Post is how I would do it.
http://tnttt.com/viewtopic.php?t=14532
But I don’t have AC in my house and never had one in the tent when camping.
Now that I am older and well, it may it's time to have one in the TD.
Chuck
Chuck Craven
Images: 62
Postby Podunkfla » Tue Mar 20, 2007 10:06 pm
CD
Caseydog... Mounting it in the galley wall is not all that bad an idea... Lots of folks have done that. If you move it all the way to one side you can make an intake vent through the side wall and cover it with a nice aluminum vent cover. The other side vent should be closed off so all the intake air is coming from outside, it will still get plenty of air. The warm air that exits the rear condenser coil will have to go somewhere... But you could just leave the galley hatch cracked open a couple inches and it should do fine. The good thing is your thermostat will work and it will look good without boogering up your nice tear. Someone here has some pix of an install like this, I just don;t remember who?
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby john » Wed Mar 21, 2007 9:16 am
To keep that old look on my tear I wanted to avoid all visible vents for the A/C. I also wanted a permanently mounted A/C. I'm too lazy for a non permanent setup. So I chose to vent through the floor.
Air enters the front set of holes and exits through the rear hole....
A/C fully hidden when the hatch is open and a view from the inside....
Image[/img]
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby caseydog » Wed Mar 21, 2007 10:32 am
Podunkfla wrote:Caseydog... Mounting it in the galley wall is not all that bad an idea... Lots of folks have done that. If you move it all the way to one side you can make an intake vent through the side wall and cover it with a nice aluminum vent cover. The other side vent should be closed off so all the intake air is coming from outside, it will still get plenty of air. The warm air that exits the rear condenser coil will have to go somewhere... But you could just leave the galley hatch cracked open a couple inches and it should do fine. The good thing is your thermostat will work and it will look good without boogering up your nice tear. Someone here has some pix of an install like this, I just don;t remember who?
As long as the unit will not overheat in my galley, I'm fine with putting it there. I was thinking of putting it to one side, and putting a hole with a nice vent plate in the side near the compressor. I guess I'd need to deal with condensation watter, too. A simple pan with a plastic tube running out the bottom of the TD should deal with that.
I guess running inside a galley at night is no more likely to overheat the unit than running out in the open air on a hot Texas summer day. I just want to make sure that one vent in the galley would provide enough ventilation for the "outdoor" side of the AC unit.
Anyone else want to chime in on this method?
CD
caseydog
Images: 515
Postby b.bodemer » Wed Mar 21, 2007 11:30 am
Jim's suggestion of the second door makes me think I might have a door insert, much like I've seen people do for their screens. I'd be set up under a 12' x12' shelter so the door could remain in it's open position and the insert idea could work real well....................
I'll only need ac sometimes so I'm looking for a temporary solution.
Great ideas have been posted in lots of past and recent threads.
Barb
b.bodemer
Images: 328
Postby caseydog » Thu Mar 22, 2007 1:38 pm
Well, I dove in and got it installed between the galley and the sleeping area. I just need to do some caulk and trim work to cover the gaps, and run a drain hose for condensation.
Here it is from the galley side, with two of the screwdrivers used during the installation. :lol:
And here is the inside view -- trim needed for those gaps.
I need to put a vent in the side of the TD for intacke of air to cool the AC workings, and I will probably put one of my fancy Mushroom Vents (plumbing vent cap and pipe) above the unit for hot air to escape.
caseydog
Images: 515
Postby lcurrie » Thu Mar 22, 2007 7:52 pm
Amen, my brother!
lcurrie
Postby Dooner » Thu Mar 22, 2007 8:21 pm
Hey Caseydog,
You will need alot more vent to get that hot air out of there. You will need close to the same size as the coil at the back of the unit. There is an old thread that explains that. I'll search and post.
Found it. Read these.
http://www.tnttt.com/viewtopic.php?t=4563&postdays=0&postorder=asc&start=0
Dooner.
TED NUGENT FOR PRESIDENT!
Dooner
Images: 69
Postby Podunkfla » Thu Mar 22, 2007 8:37 pm
Dooner wrote:Hey Caseydog,
Caseydog... Yeah, I agree with Dooner. You will not be able to dump all that heat into the galley area without a pretty good sized vent... or just cracking open the hatch, like I mentioned before. Of course, you could just run it like it is with the hatch open. John's vents from the bottom look interesting... Looks like a good idea to me.
I think I'm just gonna take the easy way out and build mine into the tongue box.
<B>~ Brick
Podunkfla
ol' noodle haid
Images: 5
Postby caseydog » Sat Mar 24, 2007 2:12 pm
Well, what if I force the air through the small vent with a vent fan? That should have a similar effect to a largervent, wouldn't it?
The way a Little Guy is made, the bottom vent idea wouldn't be practical.
I don't want a huge vent on my galley hatch, if I can help it.
leaving the galley open a bit, or all the way, is okay in some circumstances, but not in others.
I'm hoping a small vent with a fan will work. What do you think?
CD
caseydog
Images: 515
Postby Miriam C. » Sat Mar 24, 2007 2:30 pm
Seems to me what we need is some HVAC guidance on how much airflow we really need for small units that are enclosed. 8) Must be a chart or maybe someone can get their home service person to give some guidance. :worship:
