So I want to cut the top rear corner off , where the hinge is mounted to the top & do more of an arc to match the hatch . Can anyone do some Photoshop madness & show what it could look like.
I would also want ya'll to take into consideration on when I cut the flat top into an arc , would the hatch have to be completley rebuilt or could the arc from the hatch be matched & would the hatch have to be cut shorter or made longer??
What I see in doing this , remove the hinge , peel back the skin & underlayment ,remove the spar that the hinge is screwed to ,cut the sides to match the arc on the hatch , move or modify any thing inside , then lay the underlayment ,top & spar back down ,locate the hinge & adjust the hatch any way needed.
Ok , hit me with your best shot!
