What do you guys use to get all the dust off with? My first TTT, I used a tack cloth but found it left threads in the wood. Paper towels were even worse.
I don't have an air compressor (
Jeff
halfdome, Danny wrote:Jeff, It sounds like you need to do some more sanding starting with 100 grit, 120 grit and finish it off with 150 grit. I usually sand fairly slow and make 3 or more passes before going to the next finer grit of sandpaper. You'll get a superior finish that way. If you don't have a compressor use a horse hair fox tail followed with a tack cloth.Danny
If you don't have a compressor use a horse hair fox tail followed with a tack cloth.![]()
WarPony wrote:halfdome, Danny wrote:Jeff, It sounds like you need to do some more sanding starting with 100 grit, 120 grit and finish it off with 150 grit.
HOLY CRAP!! I've been going striaght for the throat with 220 grit and lettin' her eat! I'm hand sanding this one, BTW. I have a B&D sander but it goes way too fast and the paper gets clogged up. I also don't like the pad the paper sits on either.
Maybe I'm rushing the sanding process......... my last woodwork class was about 24 years ago. Can't remember the processes.If you don't have a compressor use a horse hair fox tail followed with a tack cloth.![]()
Uhhhhh, a what tail?![]()
Thanks Danny, for the info input.
Jeff
WarPony wrote:Man, I've really learned alot with this thread!!![]()
One big thing I've learned is that my 1/4" ply that I thought was "Made In America" came from Cheena.....BOOOOOOOO!!!Just because it is sold by an American company doesn't mean the product is MADE in America............ I'm looking right at you Georgia Pacific!!!
After looking at the skin ply thickness (or thin-ness), I don't think that, after all the sanding, I will have anything to stain if I do the 3-step program that you guys do. I've been hand sanding tonight with 220 on a block and have been pretty satisfied with the "smoothness" that's came of it. I just ran my hand around the surface and resanded the "fuzzy" spots.
I really appreciate all the info everyone has given....... I mean that. I'm probably going to resand my #1 TTT and try to get a smoother finish on it............ someday.
Thanks, buddies!!
Jeff
