Gull Wing Doors
Gull Wing Doors
Postby tyke » Mon Jun 11, 2007 11:54 am
Hi
Thought people might like to see the friction hinges and door in place.
Originally I fitted 12” hinges to the door but the weight was just a little to much so I have replaced them with 16” ones. There is no sagging with the larger hinges but I am not sure what weight they would hold if I were to try and hang some canvas sides from them.
Steve Topp
tyke
Postby Roly Nelson » Mon Jun 11, 2007 1:12 pm
Steve. are those doors high enough so you can walk under them? I can remember lunch wagons on construction jobs that have similar lift-up doors, and workers were constantly slamming their heads against their sharp corners, often with severe cuts to the foreheads.
I think those doors of yours would work fine if they could be raised even higher to eliminate any trips to the hospital in the middle of the night. However, if they are above head-height........no problem.
Roly, also playing around with a Lamborgini style swing-up door :thinking:
Roly Nelson
L'il Ol' Woody Builder
Postby emiller » Mon Jun 11, 2007 2:01 pm
Yeah I was woundering about the height also and remember someone else had the same idea but decided against it. Seams to me in that topic there where more cons than pros. I think one bad thing is trying to reach the door to close it when your inside.
emiller
Images: 157
Postby dovaka » Mon Jun 11, 2007 2:16 pm
some one needs to do some lambo doors that would be sweet
dovaka
Images: 6
Postby Endo » Mon Jun 11, 2007 2:46 pm
I like the look.
Where did you get your galley hatch prop?
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby Arne » Mon Jun 11, 2007 6:11 pm
I would not put gull wing doors on a tear if you paid me..... sorry to sound so negative, but I go in and out 10 times a day... just too much hassle..
A gull wing has to be open all the way, a regular door I can open half way, grab something, and close...
for me they just don't buy me anything... the hatch is different.. first, no choice.. second, I open it, it stays open all day...
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby bledsoe3 » Tue Jun 12, 2007 12:57 am
If the door was to raise beyond level and it was raining, all the water would run into the tear.
bledsoe3
Images: 112
Postby tyke » Tue Jun 12, 2007 10:49 am
Hi :D
I am going to give the door a try for a while. I did know of the pitfalls when I decided to try it and I built the door so I could convert it to side opening if I didn’t like it or if I spent to much time at the casualty department with head wounds.
The hatch stays were from Ebay, they are manufactured by a company called AXA and they do the job perfectly.
Steve Topp
tyke
