Skin on roof expanding
Postby ktgunder » Sat Jun 09, 2007 8:47 am
The skin on my roof is expanding and causing ripples, is there anything I can do? Or do I need to replace it? :cry:
ktgunder
Images: 9
Re: Skin on roof expanding
Postby steve wolverton » Sat Jun 09, 2007 10:23 am
ktgunder wrote:The skin on my roof is expanding and causing ripples, is there anything I can do? Or do I need to replace it? :cry:
What type of material are you using on the roof? How did you attach it?
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby MOKI SEAKER » Mon Jun 11, 2007 10:23 am
If you did like I did and used the plastic from Lowes. It will expand, I don't know if it goes back as it cools or not. I will have to replace mine, thats for certain. I just haven't decided if it is going to be next winter or maybe the following one, as long as it doesn't leak, I might just paint it camo; then no one can see it. In answer to your question, yes it should be replaced, if it makes you sad.. :oops: :(
Mark Twain
MOKI SEAKER
Images: 41
Postby Steve_Cox » Mon Jun 11, 2007 2:36 pm
I like what Moki said, replace it if it makes you sad :thumbsup: :thumbsup: :lol:
Steve_Cox
Images: 196
Postby Ira » Mon Jun 11, 2007 2:53 pm
Steve_Cox wrote:I like what Moki said, replace it if it makes you sad :thumbsup: :thumbsup: :lol:
Are we talking TDs here or marriage?
Stay on topic, will 'ya?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby ktgunder » Fri Jun 15, 2007 9:13 pm
"What type of material are you using on the roof? How did you attach it?"
I used .032 aluminum with contact cement but over the winter it seems the roof only has come free. In the direct sun it tends to buckle up a bit as it expands. Now it seems to have stretched some. It goes almost back to normal when it is in the shade.
ktgunder
Images: 9
