(The Puffin) New Tiny Trailer
Re: question
Postby steve wolverton » Mon Jun 18, 2007 1:12 pm
Jeeper92 wrote:i was thinking if I go with 6 foot wide will i be ok if my wheel base is only 5 feet
I'm not sure as I don't know much the tires stick out on a 5' trailer? Also, if you use a 5' wide trailer, you're going to have taller tires, so you'll need to notch the floor so that the tires don't rub on the bottom of the camper.
�veni, vidi, vici.�
steve wolverton
Images: 11
no no no
Postby Jeeper92 » Mon Jun 18, 2007 3:06 pm
Im towing it with a jeep wrangler, will i be ok goign 6 ft wide
Jeeper92
Re: no no no
Postby steve wolverton » Mon Jun 18, 2007 3:18 pm
Jeeper92 wrote:Im towing it with a jeep wrangler, will i be ok goign 6 ft wide
I'm not sure. Measure your outside mirrors and see how wide they are. I towed my popup behind a Wranger, but it was shorter than my Jeep so seeing around it wasn't a problem. You may have to add those towing mirrors to be able to see around the camper at 6 feet wide.
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby Mary K » Mon Jun 18, 2007 4:42 pm
Steve, The Puffin is Absolutely Beautiful inside and out!
:clapping hands: :clapping hands: :clapping hands: :clapping hands: :clapping hands:
And you are making free plans of the design? Hummmm :thinking: SWEET!!! :thumbs up1:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby steve wolverton » Mon Jun 18, 2007 5:16 pm
Mary K wrote:And you are making free plans of the design? Hummmm :thinking: SWEET!!!
Yup, that's the plan, free plans. That way more people can build their own, and I don't have to offer support. :lol:
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby mikeschn » Mon Jun 18, 2007 5:32 pm
Steve,
For the weekender standy I am going to suggest the construction style you used. You used 1/4" plywood, right, backed up with 3/4" studs? I am going to suggest moisture resistant luan backed up with 3/4" studs.
Postby Miriam C. » Mon Jun 18, 2007 5:44 pm
It just keeps getting better. :applause: :applause: :applause: The red stripe really makes it.
Steve, what size wheels do you have?
Sooooooo, whats next 8)
Postby steve wolverton » Mon Jun 18, 2007 6:37 pm
mikeschn wrote:For the weekender standy I am going to suggest the construction style you used. You used 1/4" plywood, right, backed up with 3/4" studs? I am going to suggest moisture resistant luan backed up with 3/4" studs.
That's correct. I just went out and double checked and I used 1x2's as spars. I have 6 spars in the camper. I have two spars that are doubled up, one towards the front and one at the back. The reason those spars were doubled up is because that's where two sheet of 1/4" plywood meet for the roof.
Last edited by steve wolverton on Tue Jun 03, 2008 4:53 pm, edited 1 time in total.
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby mikeschn » Mon Jun 18, 2007 6:41 pm
How did you form your curve?
Postby steve wolverton » Mon Jun 18, 2007 6:42 pm
Miriam C. wrote:Steve, what size wheels do you have?
I have 8" wheels. I'm looking for some chrome spinners too, not much luck. Since my tow vehicle has chrome wheels I may get some 8" chrome hubcaps (golf carts).
Not sure what's next. There are so many little things to do that I'll be busy for awhile. I'm in the garage working on my new seat cushions now. I'll post pics later, and I'm really happy with the way they're coming out. 8)
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby steve wolverton » Mon Jun 18, 2007 6:44 pm
mikeschn wrote:How did you form your curve?
The roof curve? I cut the 24" and 36" radius out of 3/4" plywood. I screwed the top into those as it bent around. Since the 1/4" plywood was 6' wide, it bent easily. No problems with the curve at all.
I came back later and epoxied the roof to the sides.
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby mikeschn » Mon Jun 18, 2007 6:48 pm
No no no.. I mean the 1x2s that you have following your curve...
P.S. Looking closer, it looks like you cut a couple plywood ribs to match...
Postby steve wolverton » Mon Jun 18, 2007 7:00 pm
mikeschn wrote:No no no.. I mean the 1x2s that you have following your curve...
Not sure I understand what you're asking? :thinking: The only plywood I used in the framing is the curvy parts where they meet with the 1x2's on the straight sections.
Here is the hi-res picture of it:
http://www.brochis.com/hires.JPG
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby mikeschn » Mon Jun 18, 2007 7:26 pm
That's why we talk in pictures...
Here's what I am asking. How did you cut this rib... It's 1/32" thinner than all your pine ribs, right?
Postby steve wolverton » Mon Jun 18, 2007 7:35 pm
mikeschn wrote:That's why we talk in pictures...
That's one of the 3/4" plywood curvy parts that I was talking about. :D Yes, it's a little thinner than the 1x2's.
�veni, vidi, vici.�
steve wolverton
Images: 11
