Cabinet door construction
Postby Creamcracker » Fri Jun 29, 2007 9:11 am
Just wanted to hear what methods people have used to construct cabinet doors --- either for the galley area or inside. I notice diverguy has the side rails of his doors mitered and they look pretty good. I want mine to have an inset panel onto which I'm going to affix those old metal signs that you can buy almost anywhere these days. For the galley I have three signs of the same size that I'm going to incorporate but am as yet undecided on door construction.
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby pauld3 » Fri Jun 29, 2007 9:21 am
what metal signs?
Lynn :thinking:
Paul & Lynn Donovan
The Toad Drop Inn
Liberal, KS
pauld3
Images: 94
Postby bobhenry » Fri Jun 29, 2007 9:36 am
pauld3 wrote:what metal signs?
Lynn :thinking:
[url]http://stores.ebay.co.uk/iposters-Poster-and-Print-Shop_Metal-Signs_W0QQcolZ4QQdirZQ2d1QQfsubZ9QQftidZ2QQtZkm[/url] them signs
Postby Mary K » Fri Jun 29, 2007 9:37 am
Philip,
I sandwiched (glued) 2 pieces of 3/16" birch ply, and glued moulding (with 45* mitered cuts) around the edges to get that inset panel look.
If you look at page 14 of my Build Picture Link below, you will find more pictures of how I built them.
Good Luck! :thumbsup:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Steve Frederick » Fri Jun 29, 2007 9:48 am
I made a frame, joined with biscuits, you could use dowels, pockets screws..Image
Then added a panel to a recess milled to the thickness of the ply, with a router.
Glued in place..
Voila!!
I just need to get them installed permanently!! :? :?
A variation with molding applied..
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby NightCap » Fri Jun 29, 2007 10:01 am
I put mine together with pocket screws on the backs. I used my left over 1/8" skin for the panels. I ran all the rails and styles through my table saw that made a notch just the right width for my panels.
#1 - 100% Done #2 - 100% Done Thinking about #3
NightCap
Images: 259
Postby Mary K » Fri Jun 29, 2007 10:13 am
Golly, we have a diverse group of builders and styles!! That is just soooooo COOL!!!! :thumbsup:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby NightCap » Fri Jun 29, 2007 10:21 am
Mary K wrote:Golly, we have a diverse group of builders and styles!! That is just soooooo COOL!!!! :thumbsup:
Mk
Sort of proves it that there really is more than one way to do just about anything eh?
NightCap
Images: 259
Postby diverguy » Fri Jun 29, 2007 10:21 am
i mittered mine in. frame is simple 45 deg(i just like that better). then cut a slot on the tablesaw the thickness of my 1/4 oak panel. glued and joined together. not perfect but i like the way they look. i think using old signs for the panels is a great idea. sounds like it will give it a route 66 look. :thumbsup:
diverguy
Images: 192
Postby khutson » Fri Jun 29, 2007 10:28 am
Not sure if you can see it in the pic but I used a router to create the channel that the insert panel would sit in. I'm not sure of all the terms sorry. The I also routered the joints male to female and glued and clamped. No screws used at all.
The whole galley
Ken
Our build blog, We try to keep it current! Check it out!
http://kennoel.blogspot.com/
khutson
Postby Classic Finn » Fri Jun 29, 2007 10:47 am
WOW and Holy Cow ... There are some real nice looking doors on all of the above...Id say we are perdy darn good craftsman if we put the thoughts and work to it...
:applause: :applause: :applause: :applause: :applause: :applause:
Very Nice :thumbsup: :thumbsup: :thumbsup:
Classic Finn ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Wow -- quick and complete responses
Postby Creamcracker » Fri Jun 29, 2007 11:14 am
These are the signs I have for the galley doors -- there'll be the three of them across the back -- notice we have a theme going on here! Perhaps not exactly original but it's what we wanted. My wife has picked up some great Route 66 fabric to make bedding. Thanks for all the input I just need to decide which way to go now :thinking:
Creamcracker
Teardrop Graduate
Images: 142
Postby volfanatic72 » Fri Jun 29, 2007 11:20 am
This is great info. Thanks to all of you for sharing your techniques!!!
:applause:
volfanatic72
Images: 6
Re: Wow -- quick and complete responses
Postby Classic Finn » Fri Jun 29, 2007 11:29 am
Creamcracker wrote:These are the signs I have for the galley doors -- there'll be the three of them across the back -- notice we have a theme going on here! Perhaps not exactly original but it's what we wanted. My wife has picked up some great Route 66 fabric to make bedding. Thanks for all the input I just need to decide which way to go now :thinking:
Creamcracker now that is DYNOMITE :applause: :applause: Those will really make nice looking doors...way to go.. :thumbsup: :thumbsup:
Where did you pick those sings up at?
Classic Finn ;)
Classic Finn
Images: 146
Postby Bob Olszewski » Fri Jun 29, 2007 11:47 am
I made mine using full tenons. Its hard to see in the photo but I cut a saw slot in before gluing it up to accept a panel retainer strip after I routered the rabit
View of panel doors
View of back of doors showing retainer strips
The strips are removable so you can change panels. The full morticed frame joints make the door very strong without the use of mechanical fasterers but are a pain to cut.
Bob Olszewski
Images: 59
