Another Generic Benroy - SaGR's build
Postby riverfront » Fri Jul 20, 2007 4:16 pm
You paid for it twice.
When you baught it and when you removed it!
Good luck!
riverfront
Postby Mary K » Fri Jul 20, 2007 5:30 pm
Well, you got in a hurry and couldn't wait for the Red Trailer. :Oh Brother: :R :R :R
Actually, it took me FOREVER to get the Red Trailer assembled, so either way ya go it's still work. Unless you have one custom made.
Your Progress is looking good though :applause: :thumbsup:
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby SaGR » Fri Jul 20, 2007 7:31 pm
We finally got the decking off just a few minutes ago. :? :dancing
Tomorrow we'll grind it smooth-ish, prime and paint and bolt down the floor.
Then it's up with the walls!
riverfront - you're bang on the money there!
MK - :lips: :gas: (there's no emoticon for "Kiss my azz"!) hehehehe
Building a small bowtop Vardo
Build thread: http://tinyurl.com/yk4hnmd
Generic Benroy: Sold to FIL/MIL
SaGR
Images: 21
Postby Mary K » Sat Jul 21, 2007 11:03 am
SaGR wrote:We finally got the decking off just a few minutes ago. :? :dancing
That would be.....
(_x_)
Mark off an acre Big Boy!!:lips: :lips: :lips: :lips: :lips: :lips:
Now Get Back to work on that trailer..... :D :D :D
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby SaGR » Sat Jul 21, 2007 11:59 am
Finished grinding and the primer is curing now (has a rust preventative in it).
We'll go back out in an hour and put the finish black on it. Let that cure for 2 hours (also rust preventative) and then down goes the floor!
:lips:
SaGR
Images: 21
Postby SaGR » Mon Jul 23, 2007 11:58 pm
As of last night the floor is down and bolted in place :D
SaGR
Images: 21
Postby Miriam C. » Tue Jul 24, 2007 12:14 am
:applause: :thumbsup: ;) That is alway a big stepping stone. It is all up from here... 8)
Image[/img]
Postby riverfront » Tue Jul 24, 2007 10:19 am
Your working hard for that Oct. 5th deadline. Keep up the good work!
Remember! It will take as long as it does. It will be done when it is time to be done. LOL
riverfront
Postby SaGR » Tue Jul 24, 2007 10:32 am
The goal is to have it "campable" mid-September. Then we'll take a few trips to fine tune where we want things and "finish" it.
SaGR
Images: 21
Postby SaGR » Wed Jul 25, 2007 8:24 pm
OK, so the floor is done and bolted down.
Now we have to pull the bolts out and countersink them! I don't know what I was thinking!
:cry:
So, now I'm stuck with figuring out which way to mount the wall once we countersink the floor bolts.
I've mocked up the wall and it will leave a portion of the bolts (including the countersunk holes exposed to the inside) as seen below. Use your imagination where the countersinks are.
Any thoughts on how to wrap the 2x2 (1 1/2" x 1 1/2") into that wall without a ridiculously thick wall?
The reason I'm thinking of the 2x2 route is I don't want to penetrate the frame any more than absolutely needed. A bolt hole through the trailer iron every 16-18" into the floor is far more holes than fit my liking as all are water infiltration points over time.
The 2x2 would be screwed and glued over the countersunk floor bolts into the floor. The wall would be through screwed into the 2x2 from the outside. But this would make my wall thicker than is actually needed.
Ideas?
SaGR
Images: 21
Postby Chaotica » Wed Jul 25, 2007 8:59 pm
As near as I can tell, you don't need the 2x2, just glue and screw into your floor framing.
Ed
Chaotica
Images: 22
Postby mikeschn » Wed Jul 25, 2007 9:01 pm
Well look who's back. Good to see you back Ed. Folks have been asking about you...
Postby SaGR » Wed Jul 25, 2007 9:05 pm
Chaotica wrote:just glue and screw into your floor framing.
What and in what direction? :D
SaGR
Images: 21
Postby Chaotica » Wed Jul 25, 2007 9:07 pm
mikeschn wrote:Well look who's back. Good to see you back Ed. Folks have been asking about you...
Yeah, I've been working out of town and haven't had much time for my build or the board. That will change by the end of August as I am being let go because of a lack of projects that my company has not planned.
btw, who are these folks that have been asking?
*looks around the board suspiciously*
Ed
Chaotica
Images: 22
Postby Chaotica » Wed Jul 25, 2007 9:09 pm
Glue the inner side of the outside ply and screw through the ply into the floor framing from the outside.
Ed
Chaotica
Images: 22
Users browsing this forum: Google [Bot] and 9 guests
