Sos Houston - Voyager Has Technical Problem
Postby Classic Finn » Tue Jul 24, 2007 5:44 pm
Voyager calling Houston ... Technical Problem On Main Hatch... Over...
Hatch Lock and Latch Difficulty - Request Assistance - Over..
Lil Bear Shuttled over T Handles and Latches - If you look at the radius on our Hatch. The bottom of the Hatch rests on the back side of the frame ..
Isnt that too low to install the T-Handles? Or how can the Voyager Crew Correctly Install Handles and Latches- Over.. :lol: :lol:
Voyager Crew ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Jiminsav » Tue Jul 24, 2007 6:03 pm
Voyager, this is caped Canaveral answering your mayday...looks to me like you screwed the pooch on that hatch job.
why not put T-handles on the side of the hatch so you can hook the side wall with the cam, Over.
Jim in Savannah
Jiminsav
Images: 40
Postby Classic Finn » Tue Jul 24, 2007 6:08 pm
Jiminsav wrote:Voyager, this is caped Canaveral answering your mayday...looks to me like you screwed the pooch on that hatch job.
Caper Cannibal I Mean Canaveral Sir... Screeeeewed Da Pooch Sir?.. Over. :lol: :lol: :lol: :lol:
Install T Handles From The Side? - Over :thinking: :thinking:
Voyager Crew :roll: :roll: :lol: :lol:
Classic Finn
Images: 146
Postby mikeschn » Tue Jul 24, 2007 6:15 pm
Someone had to add the photo!!! :duh:
Postby Classic Finn » Tue Jul 24, 2007 6:17 pm
Voyager to Houston Capn Mike Any Advice? Over :lol: :lol: :lol: :rofl2:
Voyager Crew... Over
Classic Finn
Images: 146
Postby mikeschn » Tue Jul 24, 2007 6:21 pm
Yep, glue the hatch shut and stay warm! LOL!
P.S. I added the movie photo rather than the real McCoy, since they are more readily available.
P.P.S. Finn, I've seen hatches that low and that wrapped around before. As long as your hatch can clear your sidewalls, you can install your hardware.
What kind of a problem are you anticipating?
Postby Classic Finn » Tue Jul 24, 2007 6:24 pm
mikeschn wrote:Yep, glue the hatch shut and stay warm! LOL!
Naaaaaa - to reach the kitchen - needs lil easier access... :lol: :lol:
Voyager Crew..
Ps Capn Mike any serious suggestions...Over :worship:
Voyager Crew May have a Nice Idea ... But too early to tell...
Classic Finn
Images: 146
Postby mikeschn » Tue Jul 24, 2007 6:27 pm
With the hardware you have pictured, you'll have to install it all the way down. It's not as bad as you might think.
The only other option is to go with a garage door style lock, which would allow you to install the latch higher up.
Postby Classic Finn » Tue Jul 24, 2007 6:45 pm
Mike Im not sure if that shaft is long enough...Maybe Im wrong.. but again I have a small doubt.. here is what I would sort of want it to look like ... with the Handles...Gee by the time I get done with the Hatch lights and warning reflectors and all it,ll look like ... DASHBOARD... :lol: :lol: :lol: Notice fog Light (Lower Left Corner Frame)
Here is a photo..
Voyager who Crewed Da Pooch.... :lol: :lol: :lol:
Classic Finn
Images: 146
Postby Classic Finn » Tue Jul 24, 2007 7:09 pm
mikeschn wrote:With the hardware you have pictured, you'll have to install it all the way down. It's not as bad as you might think.
Dear Mike
Maybe it looks a lil awkward since Ive never seen one LIVE sort of speak..
Another thing we were thinking of is sinking an area on each side like a pocket and finish it off nicely so the T - Handles are in an individually enclosed pocket like.. do you understand what I mean possibly?
Is that ok looking that low as on that photo above?
Classic Finn ;)
Classic Finn
Images: 146
Postby Jiminsav » Tue Jul 24, 2007 7:13 pm
screwed the pooch means really, really, REALLY, screwed up..* :shock:
and what I'm suggesting is to mount the handles a little bit closer to the edge and up from where your at in the pic and hook the side wall instead of the floor to latch it.
Jim in Savannah
Jiminsav
Images: 40
Postby Classic Finn » Tue Jul 24, 2007 7:20 pm
Jiminsav wrote:screwed the pooch means really, really, REALLY, screwed up..* :shock:
Jim Thank You
I m beginning to see the Light as to what you suggest..... :scratchthinking: :designing: :coffee:
Classic Finn
Never heard that expression... but my mind did wander in the gutter there for a sec... :yes: :duh :lol: :lol: :lol: :D
Classic Finn
Images: 146
Postby Classic Finn » Wed Jul 25, 2007 8:39 am
This here be the Voyager Over - Houston we have our Hatch Problem Solved... It is a Go - Over... Cargo Hatch Cleared - Over
Voyager and Crew..Back to The Stars..Over.. :thumbsup: :thumbsup: :thumbsup:
We,ll have photos sent asap - Over. :lol: :lol:
Classic Finn
Images: 146
Postby tonyj » Thu Jul 26, 2007 9:15 pm
Just in case you need to and hadn't thought of it, the square rod on the handle can be replaced with a piece of longer stock. Just a matter of drilling a hole for the pin and cutting to the length you need.
My latches go into the wall and not the floor.
tony
tonyj
Images: 160
Postby Classic Finn » Fri Jul 27, 2007 2:33 am
tonyj wrote:Just in case you need to and hadn't thought of it, the square rod on the handle can be replaced with a piece of longer stock. Just a matter of drilling a hole for the pin and cutting to the length you need.
Thank You Tony
Would you happen to have a photo of your latch and lock..
Thanks I just checked that rod does come out quite easily..Now why didnt I notice that earlier... :oops: :oops: :thinking:
Classic Finn ;)
Classic Finn
Images: 146
