Has any body tried this?
Postby Cliffmeister2000 » Thu Aug 02, 2007 9:43 am
Someone on the forum did a structure like that, and had the plywood cut with a waterjet for perfect cuts. Do a search -- or maybe somebody has a link they can post here.
G
Sounds pricey!
Cliff
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby Arne » Thu Aug 02, 2007 9:47 am
DZHAZARD: on your tongue box, what kind of insul is that, and did you have to kerf it to make the bend?
I'm getting to that point and need all the info I can get.... thank you.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Dave Bob » Thu Aug 02, 2007 1:09 pm
G
Sounds pricey!
Cliff
Here is the thread http://tnttt.com/viewtopic.php?t=16939
Its 1/2 inch plywood or 15/32ths, the prelimanary price he quoted was not that bad considering its for a kit with both sides, doors and hatch ribs. I think he is still in the planning stages though.
Dave
Never say "What else could go wrong?"
Because it usually will.
Dave Bob
Images: 26
Postby ssrjim » Thu Aug 02, 2007 10:21 pm
Cliffmeister2000 wrote:ssrjim says:
The only issue I see is a lot of waste and extra cost.
Although there would be a lot of waste, not appreciably more than using solid plywood sides. They would probably still have to be skinned on the inside at least. Besides, the real reason is my lack of confidence in keeping the sides straight with thin plywood and a pine frame. By using this method, I am virually guaranteed a nice, smooth sidewall. As far as cost, relatively minor increase over using thin ply and pine, unless I used furring strips and hand selected them for straightness.
I have done some more drawing. I don't want to upload them, because the detail is lost at 640 x 480, so please follow my link. This design will allow me to put a 10 foot Weekender on an 8 foot trailer. Thanks, Mike, for the weekender design, and Joanne, for the great ideas from your build!
http://picasaweb.google.com/cliffneff/TeardropShots
Cliff
That's what I did the furring strips for the two I have build.
93079
ssrjim
Postby dhazard » Thu Aug 02, 2007 10:28 pm
Arne wrote:DZHAZARD: on your tongue box, what kind of insul is that, and did you have to kerf it to make the bend?
the white insulation with blue lettering is 2 layers of 3/4” Styrofoam. I used a screwdriver to put some creases in the back and it bent with no problems. The gray insulation that is on the inside for sound is an antifatigue floor mat.
Many miles and many tears. Times were hard but now they're changing.
You should know that I'm not afraid.
dhazard
Images: 122
Postby dhazard » Thu Aug 02, 2007 10:34 pm
Cliffmeister2000 wrote:To make this weekender, is going to require 2 sheets of 4 x 10 plywood. I can think of 3 jointing techniques:
1/2 lap, tongue and groove, and spline. With spline, I have been playing with different ways to do that, too.
Any good or bad experiences with any of these? I have never tried to lengthen a sheet of ply before.
Cliff
Cliff I came up with a 4th technique, I used a hinge…
dhazard
Images: 122
Postby Micro469 » Thu Aug 02, 2007 11:14 pm
Cliff
Man, I really gotta see your trailer.... When are you coming to Ontario???? :thumbsup:
John
Micro469
Images: 382
Postby Cliffmeister2000 » Thu Aug 02, 2007 11:44 pm
_________________
That is awesome, man! How long did it take you to put all those swirls in the (I assume aluminum?)?
Cliff
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
