Someone on the forum did a structure like that, and had the plywood cut with a waterjet for perfect cuts. Do a search -- or maybe somebody has a link they can post here.
G
Sounds pricey!
Cliff
G
Cliffmeister2000 wrote:Someone on the forum did a structure like that, and had the plywood cut with a waterjet for perfect cuts. Do a search -- or maybe somebody has a link they can post here.
G
Sounds pricey!
Cliff
Cliffmeister2000 wrote:ssrjim says:The only issue I see is a lot of waste and extra cost.
Although there would be a lot of waste, not appreciably more than using solid plywood sides. They would probably still have to be skinned on the inside at least. Besides, the real reason is my lack of confidence in keeping the sides straight with thin plywood and a pine frame. By using this method, I am virually guaranteed a nice, smooth sidewall. As far as cost, relatively minor increase over using thin ply and pine, unless I used furring strips and hand selected them for straightness.
I have done some more drawing. I don't want to upload them, because the detail is lost at 640 x 480, so please follow my link. This design will allow me to put a 10 foot Weekender on an 8 foot trailer. Thanks, Mike, for the weekender design, and Joanne, for the great ideas from your build!
http://picasaweb.google.com/cliffneff/TeardropShots
Cliff
Arne wrote:DZHAZARD: on your tongue box, what kind of insul is that, and did you have to kerf it to make the bend?
I'm getting to that point and need all the info I can get.... thank you.
Cliffmeister2000 wrote:To make this weekender, is going to require 2 sheets of 4 x 10 plywood. I can think of 3 jointing techniques:
1/2 lap, tongue and groove, and spline. With spline, I have been playing with different ways to do that, too.
Any good or bad experiences with any of these? I have never tried to lengthen a sheet of ply before.
Cliff
dhazard wrote:Cliffmeister2000 wrote:To make this weekender, is going to require 2 sheets of 4 x 10 plywood. I can think of 3 jointing techniques:
Cliff
Cliff I came up with a 4th technique, I used a hinge…
_________________
Users browsing this forum: Bing [Bot] and 5 guests
