by 48Rob » Fri Aug 03, 2007 12:41 pm
Hello Mary,
An expert is a position I have yet to qualify for, but...
I've discovered that most do it yourself plug cutters are far from sharp, and thus chip and splinter.
You can drill a batch, then carefully belt sand the tops to get back to good wood, before popping them out.
When ever I'm not trying to make the plug "dissapear" I prefer beveled hardwood plugs, as once glued and driven in, they compress the wood around them, leaving no gaps.
Once flush cut and sanded, the contrasting look can't be beat.
When I don't want them to stand out, I'll cut some from the same stock they're going into.
Most Drill presses have a set of pulleys, one on the motor, one on the spindle.
Each has several positions, like the sprocket on the back of a 10 speed bicycle.
Changing which slot the belt runs in, determines the speed of the spindle.
There is generally a diagram inside the lid or cover to give you the speed versus position.
Rob
