bgordon wrote:Howard,
Thanks for the info!
By the way, why do you want to add two layers of masonite? I think one layer will be quite adequate if you still want to add aluminum, not so? Or am I missing something?
Could you post a photo of the profile, or perhaps a scanned drawing? I agree with Classic Finn. The profile looks cool!![]()
mikeschn wrote:Howard... It looks really good.
re your aluminum question, I used .040 because that's what I could get. I think .032 would work just fine also.
As you probably already know, the aluminum is bonded with an adhesive, and then captured under the edge molding. In practice the adhesive doesn't hold very long, but it does help keep it sticking to the side of the plywood.
P.S. Are you going to use CPES on that masonite?
