Why not a vinyl top?
Postby deputydogrick » Tue Sep 11, 2007 4:40 pm
At the chance of redundancy, why not a glue on vinyl top? Anybody do it with sucess? How to do it, where to get materials, how well does it stand up, and what about colors? :thinking: I'm not leaving till I get answers. (just kidding, sort of). I've got a base of bendable plywood, good and solid.
Keep it fun, Move at your own pace, Don't get hurt
"Nurture your mind with great thoughts, for you will never go any higher than you think!" Joel Volk
You should never meddle with dragons...............for you are crunchy and good with ketchup
deputydogrick
Images: 82
Postby teardropsleeper » Tue Sep 11, 2007 4:46 pm
teardropsleeper
Re: Why not a vinyl top?
Postby Classic Finn » Tue Sep 11, 2007 4:54 pm
deputydogrick wrote:At the chance of redundancy, why not a glue on vinyl top? Anybody do it with sucess? How to do it, where to get materials, how well does it stand up, and what about colors? :thinking: I'm not leaving till I get answers. (just kidding, sort of). I've got a base of bendable plywood, good and solid.
We are working on a vinyl top here In Reindeerland on our tear...Were just waiting for the vinyl to be sewn since it needs seams to be done plus we are using a few mm in thickness padding underneath ... so we,ll post more details..as we go along...
Here they do it on cars all the time.. and weve got the 4 seasons to go along with it..with good results regardless of the weather changes. I also have a professional to help us install it.. 8)
Wife says I can choose any color as long its Burgundy or Red Wine in Color.. :lol: :lol:
Classic Finn ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby elmo » Tue Sep 11, 2007 5:09 pm
I might have to try this on mine! HMMMMMM...... :thinking:
It's scary when you start making the same noises as your coffee maker.
elmo
Images: 216
Postby deputydogrick » Tue Sep 11, 2007 5:28 pm
Thanks for the input, good info, but I'm still not going away, I want to know about padding and glue or how to fasten it down. We could start a whole new trend here. Kind of like a 60's 70's thing when all cars had vinyl tops. appears to be less expensive too! Classic Finn, is your professional coming to the states anytime soon? We'll give them free room and board.
deputydogrick
Images: 82
Postby cuyeda » Tue Sep 11, 2007 5:34 pm
Check with Leon, I believe his teardrop has a vinyl top. I've seen his rig up close, and looks great!
Leon's Teardrop
Cliff & Vanessa
cuyeda
Postby rbonner » Tue Sep 11, 2007 5:37 pm
u could always use snaps on the side about an inch or 2 down like on my jeep. the front on on the jeep has a little plastic rod sewn in it and it slides in a C shaped track like an awning. At 70 in the rain it doest leak or blow off!
If you dont start, you,ll never get finished! http://s224.photobucket.com/albums/dd170/RonBonner/
rbonner
Postby Chaotica » Tue Sep 11, 2007 6:19 pm
There are some tips about vinyl in this thread.
http://tnttt.com/viewto ... sc&start=0
Ed
Chaotica
Images: 22
Postby Leon » Tue Sep 11, 2007 6:29 pm
I think this is the stuff I used http://www.rochfordsupply.com/product_listing.asp_Q_CatID_E_407_A_SubCatID_E_430_A_ProdID_E_3255
It's 78" wide so it doesn't require seams to cover a 5' teardrop. I glued it onto a 5/16 landau closed cell foam. The only probem I had was not letting some of the contact cement properly flash off so I got a couple bubbles under it that are hard to notice most of the time.
cuyeda wrote:I've seen his rig up close, and looks great!
Cliff - you heading up for Rivernook this year?
Leon
Images: 21
Postby Classic Finn » Tue Sep 11, 2007 6:33 pm
deputydogrick wrote:Thanks for the input, good info, but I'm still not going away, I want to know about padding and glue or how to fasten it down. We could start a whole new trend here. Kind of like a 60's 70's thing when all cars had vinyl tops. appears to be less expensive too! Classic Finn, is your professional coming to the states anytime soon? We'll give them free room and board.
I can ask him for you.. ;)
Ours will be coming down both sides about 4cm and under the moulding..
Also under the moulding is a rubber moulding with butyl tape so it will seal properly ..and lock into place. and the top insert is much narrower also.
I see now the moulding we have here is a little different to that most commonly used in the States..
Classic Finn :thumbsup:
Classic Finn
Images: 146
Postby cuyeda » Tue Sep 11, 2007 6:41 pm
Leon wrote:Cliff - you heading up for Rivernook this year?
Leon,
Yes, we will be there, and I won't be the only person in a tent this time! er, uh let me rephrase that... My wife and I will have a trailer this time.
Cliff & Vanessa
cuyeda
Postby WarPony » Tue Sep 11, 2007 7:00 pm
WarPony
Images: 289
Postby deputydogrick » Tue Sep 11, 2007 8:04 pm
war pony,
Now you're teasing me, where did you get it and what is it called?
Rick 8)
deputydogrick
Images: 82
Postby Chaotica » Tue Sep 11, 2007 8:20 pm
deputydogrick wrote:war pony,
Rick 8)
It's called diamond plate vinyl and I believe the link that teardropsleeper posted has it.
Ed
Chaotica
Images: 22
Postby WarPony » Tue Sep 11, 2007 8:43 pm
Rick 8)
It is called vinyl diamond plate, as Chaotica said and I picked mine up at my local car interior guy.
Jeff
WarPony
Images: 289
