GMC headlight buzzer solved
Postby del » Wed Sep 12, 2007 6:38 pm
I have a 1997 GMC half ton PU. Trouble is if I leave the lights on and turn off the key, silence, no buzzer. Did the Canadian models have a buzzer? Where do I find the unplugged buzzer?
del
del
5000 Club
5000 Club
Images: 410
Postby demtears » Wed Sep 12, 2007 8:52 pm
Hey Del, Usually headlamp and seatbelt warning buzzers are located left side under dash just above brake pedal or kick panel area. Could be a small black or white box if no wires are unplugged look for a little box that is perforated (most are) with holes. If you cant locate anything that could be identified as this, Your local dealer could look up the part# and show you what the part looks like so you will know what you are looking for. good luck!
Hope this helps out! :roll:
Darrin
demtears
Images: 26
Postby del » Wed Sep 12, 2007 10:40 pm
Hey thanks Darrin will check it out tomorrow (in the day light).
thanks del
del
5000 Club
5000 Club
Images: 410
Postby Roly Nelson » Fri Sep 14, 2007 8:49 pm
Del, are you and I the only member of the 40" wide club? 40" widers, feel free to chime in here.
Roly, 40" wide and proud of it. :thumbsup:
Roly Nelson
L'il Ol' Woody Builder
Postby del » Fri Sep 14, 2007 11:10 pm
Roly Nelson wrote:Del, are you and I the only member of the 40" wide club? 40" widers, feel free to chime in here.
Someone else built a teardrop shaped cargo trailer for their motorcycle, on the 40" frame, but that is the only other one I know of.
del
del
5000 Club
5000 Club
Images: 410
Postby Lesbest » Sun Sep 16, 2007 8:19 pm
That buzzer should be the same one the key uses and is a box about 1/2 in. thick and about 1 1/2 inches square. It is usually plugged into the fuse block that is above your left foot. It could be bloe, grey or black. When you unplug it it usually has 5 to 6 electrical spades on it. They do wear out.
Good luck.
Les
Music is like chocolate.......you can't really enjoy it unless the rappers are gone.
Lesbest
Images: 7
Postby del » Tue Sep 18, 2007 5:58 pm
Lesbest wrote:That buzzer should be the same one the key uses and is a box about 1/2 in. thick and about 1 1/2 inches square. It is usually plugged into the fuse block that is above your left foot. It could be bloe, grey or black. When you unplug it it usually has 5 to 6 electrical spades on it. They do wear out.
Good luck.
Les
Found it. Went to the dealer and they wanted $33 dollars for it. Next I went to a junk yard that tends to have late models (the 90s are late model here in Yakivegas). Found one in a s-10, took it to the counter, and the man said I could have it, no charge. Came home and tried it, success.
thanks to all del
del
5000 Club
5000 Club
Images: 410
