Stores near LCGII for last minute ... forgets ?
Moderator: 2bits
Postby sdtripper2 » Wed Oct 10, 2007 10:58 pm
Can anyone from last year give any information on distances, time diriving
and what type of stores are close to the LCGII park?
Grocery Stores in the area
http://tinyurl.com/2epyx7
Walmart Stores in the area
http://tinyurl.com/2gbu7f
Costco
None as the words of the MadOne says it all
"Nearest Costco is wan-meal-yon miles away"
Other?
sdtripper2
Search Garoux
Images: 168
Postby madjack » Wed Oct 10, 2007 11:26 pm
Steve, we drive up thru the woods from the South...coming from that direction there are a couple Cstores, gas stations and even a Pizza place within a couple of miles...going North back toward the interstate, there are several stores and a Wall Mart not too far away...keep in mind that you are only about 20 mi away from Bossier City....nearest Costco is wan-meal-yon miles away :o :lol: ;) .........
madjack 8)
Postby sdtripper2 » Thu Oct 11, 2007 12:09 am
Jack:
Looks like I should shop near Huston before traveling on uP on some path
to the gathering if I want to get some fresh food. Seems that area near the park may not have big stores.
Thanks for the information on Costco... 8)
sdtripper2
Search Garoux
Images: 168
Postby madjack » Thu Oct 11, 2007 12:16 am
Steve, I don't know what route you are taking but there are plenty of stores within 20 mi of the park...if you come up from the south(US 71) as we do, the last town with a regular grocery is Coushata...if you come up on US 79 or US 59, you will be passing thru the Shreveport/Bossier City area, where you can shop till ya drop..........
madjack 8)
if memory is right
Postby starleen2 » Fri Oct 12, 2007 2:12 pm
You would be better to stop on the interstate somewhere for supplies before exiting the interstate to the park. There are two or three small convenient stores along the way in the small communities. Tina’s (BYW Tina’s has gasoline) is the closest to the park, however with this many campers with plans to stop along the way, it is pretty easy to deplete these stores.
starleen2
5th Teardrop Club
Postby caseydog » Fri Oct 12, 2007 2:19 pm
sdtripper2 wrote:Jack:
There are plenty of big-box stores in Shreveport, but if Houston is the last place you spend the night before LCGII, then you may want to stock up there.
CD
My build journal is HERE
caseydog
Images: 515
Return to South Central
