the jelly belly build
Re: Fiberglass Supplies & Such
Postby del » Mon Oct 29, 2007 11:37 am
Randy S. Hager wrote:Dell:
Order a couple of catalogs. Order Wicks Aircraft Supply in Ill. and from Aircraft Spruce in Cal. You’ll find tapes that are already on a bias call Biax tapes. Also get the Peel Ply to go along the edges to blend the tapes in. (feather edged) This is how they do it on the fiberglass homebuilt airplanes. You will be surprised at how the edges disappear.
:o
I have tried cutting cloth on a bias, and the results were horrible, the cloth has no strength if it won't stay in the joint. The floor gets glued down over these joints, so they will never be seen again.
del
ps off to Moxee to rebuild the hinge, Binford model 4000 coming soon.
del
5000 Club
5000 Club
Images: 410
Postby angib » Mon Oct 29, 2007 2:21 pm
Bisexual (er, sorry, biaxial) fabric is not ortho fabric turned 45 degrees - it behaves quite, quite differently. You can expect to get a single piece of biax fabric to cover half a sphere without a wrinkle, which is not something any ortho fabric could do. You should try it, it's wonderful stuff - it's like someone invented glass that wants to cooperate with you.....
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Miriam C. » Mon Oct 29, 2007 3:16 pm
del wrote:I put sealer in the body mount bolts, and installed jam nuts. Later I realized how far the bolts sucked into the wood. Should I be concerned?
del
If you think that washer will sink all the way through you might want a thicker washer or wider or different shaped . ;) :D
Postby Steve Frederick » Mon Oct 29, 2007 4:44 pm
If you're concerned, how about popping blocks of hardwood into these openings, re-drill, then use a longer bolt..
Your build is Mahhhh-v-lous ;) :thumbsup: :thumbsup:
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
Postby del » Mon Oct 29, 2007 10:37 pm
angib wrote:Bisexual (er, sorry, biaxial) fabric is not ortho fabric turned 45 degrees - it behaves quite, quite differently. You can expect to get a single piece of biax fabric to cover half a sphere without a wrinkle, which is not something any ortho fabric could do. You should try it, it's wonderful stuff - it's like someone invented glass that wants to cooperate with you.....
Andrew
Next time I buy tape, i will keep an eye out.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Mon Oct 29, 2007 10:51 pm
del
I found some steel to make larger washers from. It is thicker, larger, and different shaped.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Mon Oct 29, 2007 11:33 pm
Steve Frederick wrote:If you're concerned, how about popping blocks of hardwood into these openings, re-drill, then use a longer bolt..
I think my home made washers will spread the load far enough, and still leave room for insulation.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sat Nov 03, 2007 9:43 pm
Last summer I told my neighbor I would help him fix the front end on his 69 c10 (I replaced 4 original ball joints [cold rivets are a PITA], 4 control arm bushings[one had over a 1/4 play], tie rod ends, sway bar bushings, and shocks), in trade I get a beat up dodge dakota (has the parts I need to fix my dakota convertible). All this to say he brought the pick up over Sunday, and progress slowed on my trailer. This week I did rebuild the hinge, so here is the Binford headbanger model 4000 in primer.
Paint tomorrow.
del
del
5000 Club
5000 Club
Images: 410
Postby Mike C. » Sat Nov 03, 2007 10:46 pm
Well del, all I can say is....... those are some kind of hinges. Wheweeeee!
We will rename you the " Hingemeister. "
I can hardly wait to see the completed trailer in person.
Great job. :thumbsup: :applause: :applause: :applause:
Uncle M ( Mike )
Mike C.
our Uncle M
Postby del » Sat Nov 03, 2007 11:28 pm
Mike C. wrote:Well del, all I can say is....... those are some kind of hinges. Wheweeeee!
I want to see the trailer complete too, where are those teardrop fairies. I wish the hinge did not have to be that large, any smaller and it would not open 90. Next trailer gets normal hinges.
del
del
5000 Club
5000 Club
Images: 410
Postby Jst83 » Sun Nov 04, 2007 6:45 am
del wrote:I want to see the trailer complete too, where are those teardrop fairies.
del
I sure can't help you with that all I have is Teardrop Gremlins living under mine :lol:
What's the weight of the hinge? It looks large standing next to the propane tank. It is impressive. :thumbsup:
Jst83
Images: 215
Postby mikeschn » Sun Nov 04, 2007 7:35 am
That trailer build is a much bigger job than I ever thought it would be. I'm glad you are building it, and not me. :phew:
Postby del » Sun Nov 04, 2007 10:31 am
del
The teardrop gremlins have taken up residence here. I am too scared to weigh it, and the propane tank would be bigger if I moved it closer, it is two or three feet away and on the ground.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sun Nov 04, 2007 10:37 am
mikeschn wrote:That trailer build is a much bigger job than I ever thought it would be. I'm glad you are building it, and not me. :phew:
Than you thought it would be? Do you think you hold a monopoly with that thought? If I knew how much work this would be, I would have built an easier trailer. Too late now, have to finish this one.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sun Nov 04, 2007 11:58 pm
Today I painted the hinge, looks just like yesterday only yellow. I worked on the counter.
The farthest open space gets an ice chest.
The other two spaces get removable pieces so I can have access to the lower part. Next year I would like to glue a cover over the counter (have not decided what material), should I prime it now?
del
del
5000 Club
5000 Club
Images: 410
