Custom built frame made from 2”x 2” x 1/8 “steel with 2” receiver on rear for bike rack
Custom built flexride axle with 5 bolt hubs and mounts for electric brakes and splined shaft for adjustable start angle
2 custom aluminum mag trailer wheels
2 radial tires
2” ball tongue
Bull dog jack with detachable pad and wheel
2 Atwood stabilizer jack
2 Amber LED marker lamps with SS Bezel
2 Red LED marker lamps with SS Bezel
2 oval red led turn / tail light
2 rectangular sliding windows with screens
2 round lights for mounting by the door
1 ss 30 amp 125 Volt boat power connector
7 lead RV plug with junction box mounted on frame
Wiring for trailer lights
3 100 foot rolls of 12 gauge primary wire colors R,G,B
JVC CD player
50 Foot of speaker wire
White Formica countertop
Floor is poplar and #1 pine biscuit joint construction with ¾ foam insulations and Baltic birch plywood
Walls are poplar/ #1 pine with oak around door frame ready for insulation
Floor and walls are epoxy glued and sealed
Frame has been etched and coated with POR 15 paint
I also have a little epoxy left over that will go with it and also a sheet of insulation and 2 pieces of 1/8” and 1 piece of ½” Baltic birch plywood
View pictures in d-hartman Gallery
Don
I am located in cincinnati ohio
