Window Cutouts into a Folding Table
Postby Classic Finn » Thu Dec 27, 2007 6:20 pm
Im doing some small work for the Voyager inside since the weather is just terrible outside.
I have the 2 Camp Inn window cut outs here and I was thinking that Id make a folding table out of them since they are a nice aluminum on one side and Mahogany on the other and there is no sense in throwing them away so here Im going to make a table out of them.
What would be the best way in joining them together? By a means of a short piano hinge or just a couple of small door hinges?
I will take and add the aluminum trim around the outside diameters and revarnish the mahogany on it also..
I think it will look good. Here is a photo of the Mahogany Side - Unfinished though. It needs to be sanded and shaped a bit.
And the Aluminum Side with plastic yet..
Classic Finn ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Jst83 » Thu Dec 27, 2007 7:28 pm
Very creative :thumbsup:
I love that wood.
Jst83
Images: 215
Postby starleen2 » Thu Dec 27, 2007 7:54 pm
My vote is for the short piano hinge - provides a cleaner unbroken look and makes the two halves booked
starleen2
5th Teardrop Club
Postby rbeemer » Thu Dec 27, 2007 11:31 pm
Heikki,
I have a question: Where are you going to use the tables and is it going to be free-standing?
My concern about the hinge thing is that you need to add support to the bottom so that when it is unfolded you, it won't go past 180 degrees.
What you could do is make each into its own table with folding legs so that you and your wife(could not remember how to spell her name) could each have your own table to be used with the folding recliner chair.
Rick
If ducks had scales, would fish quack?
rbeemer
Postby Classic Finn » Fri Dec 28, 2007 4:57 am
rbeemer wrote:Heikki,
It will be used on the outside mounted onto the wall with the special hangar. I was thinking more of have one folding adjustable leg.
Its not really big enough for 2 tables seperately.
Classic Finn
Classic Finn
Images: 146
Postby halfdome, Danny » Fri Dec 28, 2007 11:24 am
Heikki, are you going to square up the two cut outs? If you are going to I would take small progressive cuts from one edge to the other until you end up with straight parallel edges. To square up the short edges you'll need a home built table saw sled. If you need a picture of one I'll take one for you. They are real handy in the shop. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Classic Finn » Fri Dec 28, 2007 6:46 pm
halfdome, Danny wrote:Heikki, are you going to square up the two cut outs? If you are going to I would take small progressive cuts from one edge to the other until you end up with straight parallel edges. To square up the short edges you'll need a home built table saw sled. If you need a picture of one I'll take one for you. They are real handy in the shop. :D Danny
Sure you can take a pic as I dont quite understand but I,ll square the inside edges and leave the outside radius on.
Heikki ;) :thumbsup:
Classic Finn
Images: 146
Postby Mike C. » Fri Dec 28, 2007 9:28 pm
starleen2 wrote:My vote is for the short piano hinge - provides a cleaner unbroken look and makes the two halves booked
I agree. I think a short piano hinge would work the best.
Uncle M ( Mike )
Mike C.
our Uncle M
Postby Classic Finn » Sat Dec 29, 2007 7:11 am
Here are the wall and table pieces..
and I order the leg for it as well. ;) :)
Classic Finn
Images: 146
Users browsing this forum: Google [Bot], Jimbodub and 1 guest
