Valterra water tank fill kit ?
Postby nikwax » Thu Mar 06, 2008 7:20 pm
I have a 15 gallon Valterra water tank (ABS) and need a fill kit. I'm a bit confused by Valterra's web site, they show fill kits with 1 1/4" barbed fill fittings, but (here's the part I don't understand) how does the fill fitting install? These tanks have 3/8" fittings pre-installed (clearly for drain and vent).
Anyone with experience with this?
Here is one example of the various kits available.
nikwax
Images: 30
Postby cuyeda » Fri Mar 07, 2008 2:11 am
I have a Valterra tank, and is slightly smaller, 12 gal (I think). I purchased a fill valve like this from http://www.valterra.com:
Image I cut a hole in the side of the tank, and used a potable PVC glue. I used a potable water hose to attach the fill connector to the outside wall.
Image from West Marine.
Note: Make sure your fill inlet is higher than the tank itself. The previous owner did not, and I have to use a bit of pressure to fill the tank due to the fill inlet is slightly lower than the top of the tank. I had few choice words to myself when I learned of this mistake made by someone else.
Cliff & Vanessa
cuyeda
Postby Steve_Cox » Fri Mar 07, 2008 6:55 am
I did it with boat parts like Cliff. Works OK mounted on the side of the trailer, would work better if it was mounted on the top behind the hatch. I use a short piece of cut off garden hose with a valve on it stuck into the tank through the deck fill to fill the tank, less spillage that way.
Steve_Cox
Images: 196
Postby nikwax » Fri Mar 07, 2008 9:44 am
cuyeda wrote:I have a Valterra tank, and is slightly smaller, 12 gal (I think). I purchased a fill valve like this from http://www.valterra.com:
cool, so you just make a hole and glue the filler into it. Thanks!
nikwax
Images: 30
Postby Dale M. » Fri Mar 07, 2008 10:01 am
A simple system and is totally invisible is to put a female hose connector and a valve in connected at one of the lower tank fittings....
What I have done is come off bottom of tank and put a valve on outlet to act as a drain. Also on drain valve I put the female hose connector.... Simply connect hose to connector and turn supply faucet, open valve into tank and let "water system" pressure fill tank through "drain".... OF course you do need a VENT at top of tank....
IF you have a a metal tank that can be pressurized, water system pressure will also fill tank and pressurize system at same time.... IF you keep "any" vent at top of tank closed.
Dale
Dale M.
Images: 18
Postby cuyeda » Fri Mar 07, 2008 4:53 pm
Dale M. wrote: snip.... OF course you do need a VENT at top of tank....
snip...
Dale
Like Dale mentioned, you need a vent at the top of the tank with either fill connection style you choose. I looped the vent tube height above the actual tank, and routed it pass the floor/frame under the trailer. When filling the tank, I watch for the overflow from the vent tube on the ground. Then I know the tank is full. Of course you knew that already, but I wanted to mention it, in case others reading this did not.
Cliff & Vanessa
cuyeda
Postby nikwax » Tue Mar 11, 2008 8:49 pm
OK, I have my fill kit, one more question: the vent. How can I rig the vent so that I don't get shmut in the tank?Maybe a valve somewhere that's easy to access?
nikwax
Images: 30
glue
Postby eamarquardt » Tue Mar 11, 2008 8:54 pm
I got confused the tank in question is abs but one of the posters referred to pvc cement. I am not sure that there is a glue that works to connect abs to pvc. Shouldn't the assembly be all abs or pvc an and appropriate glue used?
Just a thought.
Cheers,
Gus
eamarquardt
Images: 150
Re: glue
Postby cuyeda » Tue Mar 11, 2008 11:26 pm
eamarquardt wrote: Shouldn't the assembly be all abs or pvc an and appropriate glue used?
Gus
Sorry, I just used the term PVC, technically I don't know the difference, but whatever the proper plastic and glue is, make sure it is for potable water.
Nikwax,
I am sure others will chime in with good advice. I merely just looped the vent tube so that it arched up and higher than the tank. Then secured it pointing down and underneath the trailer. Provided that your fill tube is higher than the tank and relief hose.
My thoughts for my installation when filling the tank via a pressured hose, the tank will fill and overflow onto the ground. That's when I know it's filled. If you are more comfortable with making it air tight when not in use then put a simple valve on the end of that hose.
You will need an open relief valve when you fill it, and also the same relief will allow the water to flow when pumped during use. This will prevent a vacum in the tank. At the end of a trip, I open a separate drain valve and empty the tank. The next day I will close the drain valve when it's empty. Does that help?
Cliff & Vanessa
cuyeda
Re: glue
Postby nikwax » Wed Mar 12, 2008 12:43 am
cuyeda wrote:
Nikwax,
perfect, thanks! that gives me a good idea for how to do the vent.
nikwax
Images: 30
Re: glue
Postby Nitetimes » Wed Mar 12, 2008 12:54 am
eamarquardt wrote:I am not sure that there is a glue that works to connect abs to pvc. Shouldn't the assembly be all abs or pvc an and appropriate glue used?
Just a thought.
Cheers,
Gus
I believe there is one that works on all of them, at least that is what the can says and they can be a combination of different flavors. I couldn't vouch for the strength of the joint this way but I don't think that would be a major concern in this situation. :thinking:
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby nikwax » Fri Mar 21, 2008 5:14 pm
I have the same filler as cuyeda, was stumped a bit as to how to manage the 1-1/2" deck filler to 1-1/4" tank filler. West Marine had everything to do this:
1867548 Barbed Hose adapter 1 1/4" to 1 1/2"
214934 1 1/2" water hose, clear flex
282301 1 1/4" bilge hose, semi-flex
add some hose clamps, and you're in business.
nikwax
Images: 30
Postby nikwax » Wed Mar 26, 2008 6:37 pm
A tip for working with tubing in colder weather (or maybe in any weather) is to soften it up with a heat gun or hair dryer before working with it. It is much more flexible and easier to get on to the fittings.
nikwax
Images: 30
Postby john » Sat Jun 28, 2008 3:29 pm
Are these tanks like the valterra above designed for pressurized water like the water lines in a house.
I guess what I am asking is when a water system is installed and the hose connected does the pressurized water also pressurize the water tank? I know they have a vent and that would suggest the tanks are not pressurized but could the vent not have a valve on it? Perhaps a valve is installed "before" the tank and can be switched for filling the tank and switched the other way for pressure to the water lines.
How is this done??
john
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby Kens » Sat Jun 28, 2008 4:19 pm
I also have a water tank. My vent is always open. No valve what I did was put a small air filter on the end of the vent hose. Found the filter at a aqurium fish store. Hope this helps. Ken
Good day every day!
Kens
Images: 26
