This Teardrop will be 5'4" wide and 10' long not including the tongue.
I WILL BE POSTING PICTURES & EXPLANATIONS AS THE TEARDROP TRAILER IS BEING BUILT.
****WELL IT IS TIME TO START BUILDING****
This picture is of the tubing and the channel that I picked up to build my new Teardrop Trailer.
Well after looking at the steel that I had bought for my TD for awhile I decided it was a little heavier then I realy needed, so I used the steel in picture above to build a flatbed trailer out of it.http://vegasteardrop.com/flatbed_trailer_build_08p1.html
So I picked up some smaller steel tubing to use for my Teardrop Trailer.
The angle in this pic was used on my flatbed trailer.
Here I cut up some of the tubing.
Here I am using the flatbed trailer frame for a work bench to lay out the teardrop trailer frame.
Here all of the cross braces & side pieces and the front & rear pieces have been cut and laid out,Then they we're tac welded so the frame would stay square & after this side was all tacked up & rechecked to make sure it was still squared up (Looked good) now it was welded up.
Now the frame was flipped over and this side was welded up.
Here the spring shackles and springs are being welded on.
Here the coupler has been welded on to two pieces of tubing.
Here the tongue has been lined up and vise gripped on and then it was welded.
Here a center tubing was centered and welded.
I will be posting more pictures real soon.
And you can also follow this build and others on my web page at
( www.VegasTeardrop.com )
If there is any questions or Ideas as I building this Teardrop Trailer let me know I am not building this TD from plans or copying any other Teardrop Trailers, My plans are in my head,hundreds of ideas the only sure thing about this TD build is that it will be able to accomodate a Queen Size Bed
I figure some of the best trips that we have been on have been the one's that we made no plans.
We just hit the road and we end up were ever we end up.
This is the way I will be building this TD.
The Sin City Teardropper.
Ken F.
