Miriam C. wrote:![]()
Try this.
emiller wrote:Mine has a grease zerk, is there a cap on top you can take off. If not your only option is to spray some WD-40 or other thru the crank handle.
Micro469 wrote:emiller wrote:Mine has a grease zerk, is there a cap on top you can take off. If not your only option is to spray some WD-40 or other thru the crank handle.
Thanks Emiller, I'll try that. It looks Like I can remove the handle, but don't know if it comes apart. It's welded on the frame.... don't really want to try to replace it.
Miriam C. wrote:Micro469 wrote:emiller wrote:Mine has a grease zerk, is there a cap on top you can take off. If not your only option is to spray some WD-40 or other thru the crank handle.
Well really I was serious. Try gently knocking it to rattle "stuff" loose. Then spray some junk on it.![]()
Micro469 wrote:Miriam C. wrote:Micro469 wrote:emiller wrote:Mine has a grease zerk, is there a cap on top you can take off. If not your only option is to spray some WD-40 or other thru the crank handle.
AAHHH!!! You're afraid of Mary!!!!
Micro469 wrote:Miriam C. wrote:![]()
Try this.
SHEEESH... You ask for advice,and this is the best I get????? I'm gonna sic Mary on you!!!!!!!!!!
