My toungue jack is....
Postby Micro469 » Sun Apr 27, 2008 7:59 pm
very hard to turn up or down. The trailer has been sitting for almost two tears during construction, so it hasn't been used much. Anybody got any advice on how to grease it? Do I just grease the shaft or do I have to take the thing apart? And if so....how???
:oops: :thinking:
John
Micro469
Images: 382
Postby Miriam C. » Sun Apr 27, 2008 8:02 pm
Image :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: Try this. 8)
Postby emiller » Sun Apr 27, 2008 8:24 pm
Mine has a grease zerk, is there a cap on top you can take off. If not your only option is to spray some WD-40 or other thru the crank handle.
emiller
Images: 157
Postby Micro469 » Sun Apr 27, 2008 8:26 pm
Miriam C. wrote:Image :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: Try this. 8)
SHEEESH... You ask for advice,and this is the best I get????? I'm gonna sic Mary on you!!!!!!!!!!
:twisted:
John
Micro469
Images: 382
Postby Micro469 » Sun Apr 27, 2008 8:29 pm
emiller wrote:Mine has a grease zerk, is there a cap on top you can take off. If not your only option is to spray some WD-40 or other thru the crank handle.
Thanks Emiller, I'll try that. It looks Like I can remove the handle, but don't know if it comes apart. It's welded on the frame.... don't really want to try to replace it. :roll:
John
Micro469
Images: 382
Postby emiller » Sun Apr 27, 2008 8:36 pm
John if you do have to replace it, buy one the same and just take off the lock ring and put the new one on. No cutting or welding.
emiller
Images: 157
Postby Miriam C. » Sun Apr 27, 2008 8:43 pm
Well really I was serious. Try gently knocking it to rattle "stuff" loose. Then spray some junk on it. ;) 8)
Postby Micro469 » Sun Apr 27, 2008 8:52 pm
AAHHH!!! You're afraid of Mary!!!!
:R
John
Micro469
Images: 382
Postby Juneaudave » Sun Apr 27, 2008 9:22 pm
Well..I can tell you this from the frozen North, rainy, ocean salt environment...lot's of people pop the plastic cap off the top of the jack and pack it with bearing grease...others just put a bucket over the top of the jack to keep the weather out. This is a pet peave with me...on my big boat, it seemed like I was changing jacks about every year or two!!!
Juneaudave
Images: 380
Postby Steve_Cox » Sun Apr 27, 2008 9:25 pm
John,
You have a top wind bulldog tongue jack don't you? Best bet is have Mary crank on it a while to loosen it up so you can turn it. :lol:
Steve_Cox
Images: 196
Postby Nitetimes » Sun Apr 27, 2008 10:20 pm
About the only way to oil those jacks is to pour some oil down along the handle shaft, it's messy but it does work, dribble it in there until it loosens up then put a little more in, it'll run down around the threads. Also if you screw it out as far as it will go you can rub a layer of grease on the tube and run it back in, that'll help keep it from rusting in there.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Mary K » Mon Apr 28, 2008 12:37 am
:R
Noooo, I'm scared of Aunti M. :baby: I just have a paddle....she has a hammer. :shock:
But I'm not scared of Steve. Steve, I'll be bringing the paddle on the 9th. :fb
Mk ;) :R
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Gage » Mon Apr 28, 2008 1:18 am
:twisted:
Well at least you didn't have to read what I was thinking of to help. :rofl:
Image Image Image
Gage
Images: 28
Postby bobhenry » Mon Apr 28, 2008 6:29 am
The dribble method worked for me. I took an old innertube ands cut out a section. Worked down over the crown of the jack and fastened it with a radiator type worm clamp. pulled it up and filled it with a quart if cheap off brand automatic transmission fluid. Folded over the end and put a spring clamp on it. Took a day or two for all of it to leak down into a pan I placed under the jack but it worked slick as can be after about 5 minutes of running it up and down. Very little mess and just rag wipe and your ready.
Postby Mini Renegade » Mon Apr 28, 2008 2:57 pm
Try using warm cooking oil or cold diesel, I unsiezed an engine by filling the bores with diesel, but cooking oil is supposed to work.
If evvr tha dus owt fr nowt, allus do it fr thissen
Mini Renegade
