Fiberglass EggCamper Teardropp
Postby nwnoni » Fri May 16, 2008 12:05 am
Hello,
I'm looking at buying a fiberglass teardrop that's being sold as a utility trailer and so has no insulation.
How could I insulate it?
:thinking:
Thanks for any help.
--Noni
Not a teardrop builder
nwnoni
Postby goldcoop » Fri May 16, 2008 6:20 am
Noni-
Maybe Dynamat :roll:
http://www.dynamat.com/products_automot ... liner.html
-OR-
Much cheaper!
http://www.lobucrod.com/
Cheers,
Coop
goldcoop
Images: 32
Postby grant whipp » Fri May 16, 2008 11:51 am
Hi, Noni!
Another possibility would be to line the walls & ceiling with the padded & pre-patterned upholstery material found in many upholstery supply shops (some looks like tuck-n-roll, some looks like diamond-tuck, etc.). It doesn't take much padding to make a big insulative difference, and the added bonus is that it will give the trailer a much nicer feeling inside.
Don't know if you've looked at the Bell RV Liberty yet or not, but their trailers have insulation laminated into the structure as well as a thin layer of insulation under the headliner material.
Good Luck with your search! In the meantime ...
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
Postby james tillitt » Sat May 17, 2008 11:20 am
We use a product called Temp Coat to insulate odd shaped areas of our buses at work. We spray it on with a hopper gun but you could probably use a roller to apply. It smells terrible when wet but the smell goes away when it is dry. http://www.temp-coat.com/ this should answer any questions you have about it.
James
james tillitt
Images: 18
