by pete.wilson » Tue May 27, 2008 11:39 am
Hey
Another product that works is a high-Tech coating called POR-15, stops rust permanently but it's not UV protective. There is two other similar products called blackcote and Chassis Cote which run about $47 qt. expensive- yes. Used for Jeep frames and bodies. Can be purchased through Quadratec @ 800-745-5337 Free Catalog. They can provide you more information on the stuff.
Another Suggestion might to have it Rhino-lined if rust is concerned.
Pete Wilson
Why hasn't anyone found a dead bigfoot? When was the last time you found a dead deer, bear, coyote, fox, squirrel, etc. that died in the woods.........Hmmm.
