Thanks, Mike
What material are those fenders made of? Doug H. narrowed his fiberglass fenders down.
http://tnttt.com/viewto ... highlight=
You could probably use the same steps using a metal cut off, and welding it back again. A bit more grinding, and a little bondo may smooth the surface out. When the paint is applied, it should hardly be noticeable
JIML1943 wrote:How about just raising them up so you have the same clearance at the top as you do in the front and back may help the looks.
I was thinking more that maybe if you cut the front and back sections that hang below the frame, that they might look just fine without making them narrower.
benzu wrote:I was thinking more that maybe if you cut the front and back sections that hang below the frame, that they might look just fine without making them narrower.
That would be a lot easier then I wouldn't have to do any welding or bondo work.
Thanks, Larry
Mike
Mike, I say make your own fenders. Your tear is beautiful and matching fenders would really make it stand out. In my opinion.
Here's a photo of my fenders, very easy to make.
